TechPB Forum: Apex speed penalty - TechPB Forum
Apex speed penalty
#1 User is offline   Iram
Posted 17 May 2009 - 07:52 PM
That's interesting. Last time I used an APEX tip the velocity change between on/off was closer to 30 fps. Maybe I'm just remembering wrong though, or my particular APEX was defective.
#2 User is offline   Troy
  • What... is the air-speed velocity of an unladen swallow?
Posted 17 May 2009 - 10:50 PM
Or... you two were using different settings. :rolleyes:
\m/
#3 User is offline   Dr. Isotope
  • Rangers... mount up.
Posted 18 May 2009 - 02:17 AM
Also depends on which barrel the Apex tip is on-- the crappy barrel they give you is an easy 30fps drop from any other barrel. My Apex tip on a J&J kit is about a 10fps difference at most.
"A good man can be stupid and still be good. But a bad man must have brains." --Maxim Gorky
#4 User is offline   Iram
Posted 18 May 2009 - 05:18 AM
All the way on to all the way off. There aren't a lot of settings on an apex tip.
I had it running on a Freak kit. The barrel back shouldn't matter much. The tip is at the tip, and whatever effects it has to slow down the paintball would only be based on the velocity of the paintball when it reaches the tip.
#5 User is offline   Troy
Posted 18 May 2009 - 07:32 AM
I, for example, hardly ever turn it all the way on. There may not be a lot of settings, but it still matters.
\m/
