TechPB Forum: 2 control bores - TechPB Forum
2 control bores
#1 User is offline   That_guy
Posted 26 June 2012 - 03:55 PM
Ok, so what would happen if you had 2 control bores on a barrel? Like 2 underbores. A 677 and 679 for instance.
#2 User is offline   cockerpunk
  • All the Dudes
Posted 26 June 2012 - 03:57 PM
why stop at 2?
#3 User is offline   That_guy
Posted 26 June 2012 - 04:01 PM
View Postcockerpunk, on 26 June 2012 - 03:57 PM, said:
why stop at 2?
Ok 7 control bores 2" each to make a 14" barrel
#4 User is offline   mr.satire
  • Your birth is a mistake you'll spend your whole life fixing
Posted 27 June 2012 - 06:06 PM
Well if both (or all 7) were underbores nothing since the ball would simply transition from one to another and have slightly less drag in each one.
If you have one be an underbore and then one be a slight overbore (aka lurker egien barrel) then you will get an efficient barrel since the underbore section accelerate the ball while the overbore portion allows the ball to average out
its velocity, and by having a slight overbore you only loose a small portion of air due to blow by
#5 User is offline   Egomaniacal
Posted 30 June 2012 - 05:04 PM
The eigenbarrel is 1 (very slightly) tapered bore.
eiπ = − 1
#6 User is offline   bigx
  • Walk on Warior
Posted 30 June 2012 - 05:12 PM
What about a barrel that is all control bore with no porting???
#7 User is offline   TacticlTwinkie
  • *insert witty title*
Posted 01 July 2012 - 06:20 PM
it would be loud
#8 User is offline   madsnipes
  • Zef Member
Posted 01 July 2012 - 06:40 PM
it would be loud
and inconsistent
