TechPB Forum: Cocker Trilogy Bolt - TechPB Forum
Cocker Trilogy Bolt
#1 User is offline   haulinass95
Posted 15 October 2012 - 09:51 AM
I have an Autococker Trilogy, but it has a silver bolt and bolt pin, and i play woodsball, where do i get a bolt and bolt pin thats like black or some other non-metallic color that won't give me away so easily in the field? don't need anything fancy, just a cheap bolt,
This post has been edited by andrewthewookie: 15 October 2012 - 11:48 AM
#2 User is offline   Cookybiscuit
  • Schadenfreude Fanatic
Posted 15 October 2012 - 10:27 AM
Something tells me 2mm's of exposed metal isn't going to give your position away...
Stealth in paintball doesn't work, the only way to be even remotely sneaky is with a ghillie suit, and even those are difficult to utilize since movement is far more noticeable than mismatched patterns and colours. Forget camo.
#3 User is offline   haulinass95
Posted 15 October 2012 - 11:25 AM
even so, it looks stupid, and i want to replace it
Posted 15 October 2012 - 11:47 AM
You will need to look for the shorter bolts that will fit the Trilogy, or the P-block cockers.
Fear is the mind-killer
#5 User is offline   pbcanada eh
Posted 15 October 2012 - 02:33 PM
I used to play with a silver painted a5 and no one saw me cause of it you should be fine
