TechPB Forum: 68ci 4500psi deal - TechPB Forum
68ci 4500psi deal
#1 User is offline   sancho000
Posted 30 December 2008 - 11:40 AM
does the deal thing with the free sandana and sack only from buying from you directly or could i buy it at a local shop and still get the headband and sack for it?
#2 User is offline   Voudim
Posted 30 December 2008 - 08:11 PM
just buy it from the shop, the free shipping will take like 10days if you live in califorina. plus you can try to fit a tank cover over it. I still havent found a fitting cover online.... but the ninja tank is good. Be aware their are little bubbles like 60of them very small a dot size that are inbedded into the tank, I ask ninja if their is a problem they said that happens , because the coat it banked on.
No referral links in sig, thanks.
#3 User is offline   skillet72
Posted 30 December 2008 - 08:29 PM
Yes, the sak and sandana are for internet orders only. They will come with any carbon fiber system while supplies last.
Ninja paintball always recommends that you purchase your ninja products thru your local paintball store. This helps out the local community and keeps paintball alive.
Ray
If you want to swap the tank please give us a call and we will work something out.
877-NINJAUSA
Ray
#4 User is offline   Voudim
Posted 02 January 2009 - 02:55 AM
Ray
877-NINJAUSA
Ray
it's ok, I love myn, works well with the SLG, I was the winner anyways, I shouldnt be greedie
#5 User is offline   G0DW1N
Posted 06 January 2009 - 09:56 PM
are these tanks TC(TRansportation Canada) approved?
RCHA REP
EGO 8 w/ 14" deadlywind
CF 68/4500
Rotor
#6 User is offline   skillet72
Posted 07 January 2009 - 10:13 PM
The 50 cu 4.5 cf boobie - the 90 cu 4.5cf rocket - and the 48cu 3k aluminum are TC ready
The 68 4.5k cf will be very soon
Ray
