TechPB Forum: The Ultimate Vibe/SP1 Troubleshooter - TechPB Forum
  • 4 Pages +
The Ultimate Vibe/SP1 Troubleshooter All your problems solved!
#1 User is offline   Danny D
Posted 25 September 2010 - 11:21 PM
I thought i should share some insight on how ive oversome some of the many problems with my friends and my sp-1 and vibe over the years. Ive personally teched 5 different guns in a variety of problems, some requiring creative solutions:
Problem:
1. Leaking air.
2. Gun not firing
3. Parts missing
4. Mods - Trigger sticking? look here
1. Leaking Air/puffing noises
If the vibe is leaking somewhere in the gun locate the source of the leak by ear. First make sure the bolt, ASA, and reg are screwed in correctly. Then if the leak persists, easier detection can be had by taking off the grip frame.
If the leak is coming from the reg:
-your pressure may be set too low, and you may need to increase the velocity (Do NOT do this if you know your gun was set at a high enough pressure before the leak, you may blow a soloniod) Start with the reg at the lowest setting and increase slowly.
-the oring from the asa is damaged, replace it
-CO2 is being vented from your gun in the topmost reg vent. Use hpa or a remote line to prevent liquid co2 from entering
-The internals of the reg need servicing or replacement (ive had a loud trumpet noise come out of mine before and the reg seat needed to be replaced as it was sheared). This can be easily fixed. If the air is coming from the topmost of the 3 vents on the side of the reg nearest to the marker body, replace the 006 size o-ring in the overpressure vent valve. If its coming from the middle hole, it can be the piston o-ring, the lower 006 size piston o-rng or the reg seat. 10 cent fxes. If its not coming from the vents, and from the swivel, replace the swivel o-rings.
If the leak is coming from the bolt (out the breach)
-degass and reset the bolt to the rear position. sometimes initial pressurization does not set the bolt back and air leaks
-make sure the board is set to the right dwell setting (co2 vs hpa)
-If you have another bolt replace it to see if the bolt is the actual problem. If it is, you may need to replace some orings. check for damage, lube, and/or replace. The active orings that move and are subject to more wear are the inside of the bolt stop the two in the front and the small one in the rear.
-Before you replace o-rings make SURE thee reg pressure and tank pressure is reading right. 800+psi for tank, 120-180psi for reg. Get a pressure tester if possible. Also see where the air is leaking from on the bolt. Is it leaking from the bolt faace or around the bolt? Use your finger to plug the bolt face and feel. If its coming from inside, the bolt sail o-ring or the inner bolt stop o-rng is to blame. If its coming from the outside, the rear breech o-ring is to blame.
-if the bolt is stuck forward and leaking it may be the bolt sail o-ring, the rear internal breech o-ring or ay be a problem with the banjos/forward line. Check the line first leading from the noid to the front banjo.
If the leak is soming from around the board:
-Tighten up the banjo bolts! This is the prime cause of a leak! Banjo bolts get loose after a while.
-If air still comes out of the banjo bolts, it may be an oring is damaged inside the one thats leaking. Replace.
-If air is coming out of the hoses, replace the hose.
Leak from the asa: replace tank oring
Soleniod
For info on parts name and function see solenoid pic below. More solenoids are damaged by the user trying to repair it than mechanical faliure. DO NOT overtighten solenoid screws. Rely on the clips and tighten screws till snug, NOT tight.
*If the air comes out of the solonoid exaust port WHEN FIRING, AND the gun fails to fire correctly, do the following (air should be coming out of the exaust port durring firing, but it may not fire, or it may leak excessively with a low velocity, or puff out the barrel)
-replace the battery with a fresh ALKALINE 9v. Do NOT use carbon zinc 9v batteries (cheaper $$). They do not have enough current to run the solonoid.
- make sure the dwell setting is set to the correct air type (co2 vs hpa)
-Make sure your reg is not too low - DO NOT INCREASE pressure if you know it was set at the right level before the leak!!!! You may do more damage. If you have an inline pressure tester that would be ideal. Keep under 200psi, and above 100psi.
-Check the nub on the armature for dirt and damage. As well as the tiny o-ring on the inside of the soloniod.
- If using a deadlywinds hollowpoint bolt, it may be the bolt sail o-ring. Clean and lube, if it still doesnt work, replace the o-ring: Info by UV Halo
- the solenoid may need replacing
*If the air is coming from around the base of the solenoid, replace the o-ring there with a fresh 015/90.
*If the soleniod is leaking CONSTANTLY from the exaust port do the following:
-check the armature for damage. Flip over the armature, clean it if its dirty with a qtip (make sure no fibers are left), also clean the inside of the cap near the exaust port, center the coin in the top of the soloniod, then put the cap on it, again making sure the coin doesnt get off centered/unseated. Make sure no space is in between the cap and the bottom of the soloniod when screwing it back in. Air her up, and your good to go.
If it still leaks after that, you can try flipping the coin once more and making sure its centered. you will have to get a new coin for the noid (or new rubber things). If thats the case, i would try modding the current coin you have before you get a new one. Try putting some teflon tape on the nub that faces the top, or put a thin layer of hot glue or something as rubbery. Again, this is a last ditch effort in case you NEED to rreplace the coin/noid.
2. Gun is not firing
If the gun is not firing:
-Make sure you have a FRESH ALKALINE 9v. NO CARBON ZINC!!!!! ALKALINE ONLY!!!!
-Make sure the 9v wire is not pinched or damaged
-make sure no paint water, dirt or oil is on the board
-Make sure its turned ON
-make sure your dwell setting is on the right air source (hpa vs CO2)
-make sure your gun is lubed and clean
-check for leaks
-with no air in the gun, on full auto, check if the solonoid is operating (not the beeps, see if the solonoid "clicks")
- if it doesnt, unscrew the solonoid, undo the clips, and see the pins on the bottom. there may be an intermittent connection. , remove the two screws and clips. on the bottom you will see two pins and brass holes where they go in. Strip a wire, get a thin - less then hair thickness sliver of metal wire, NOT INSULATION. Put a peice of rasor thin wire (a fragment) in each hole to make sure there is a connection between the pins and the holes.
-solonoid or board may need to be replaced if above has been solved and the board does not turn on or function.
For blackheart users!
-If your eyes are malfunctioning, it will most likely be the recieving diode thats taken the shitter, OR the harness wire has been pinched and severly damaged. First make sure eyes are on on the board setting. If they dont work its the diode (detector, NOT EMITTER, unless you dont see light)
-for the diode, you can easily get one off a halo, or from an electronics store. They are standerd detector diodes. $1-2. Just solder in place. Alternitavely you can get a new harness altogether. Used on this site - $5-10. Can use ion ones!
- for the wire harness ion ones will work, not sure if others will work, but you may be able to repair the harness you have...
3. Parts List
Here is a list of all the o-rings you will need:
006 - banjo bolt (base of bolt contacting breech), Regulator: Relief valve oring (top)
008 - Regulator: Spring platform o-ring
010 - bolt tail o-ring (moving 010/70), Regulator: Relief valve (bottom)
014 - inside of the bolt stop (moving 014/70) Regulator: Spring platform o-ring (outer), Reg swivel (2x), Reg piston (moving -014/70)
015 - bolt bumper o-ring(static)/ regulator/tank
016 - bolt sail o-ring (moving - 016/70)
017 - Breach o-rings, maybe outside bolt stop and 2 back cap
018 - maybe outside bolt stop and 2 back cap o-rings
022 - rear of the back cap.
1x3mm - banjo bolts (head of the bolt)
1x4mm - reg? Possibly the O-ring on the adjuster on the reg, but theres no way of getting to it. Dont know where else this size goes.
I suggest you get a set of all of these o-rings. You may need more than one. For parts which are moving you will need a durometer of 70. All others are static o-rings and will need 90.
4. Mods
Trigger sticking:
Not really a mod, but just loosen the top handgrip screw a 1/4 turn and it should stop sticking. Either that, or clean your trigger from all the gunk over the years.
Hand tightened feedneck mod: Get a 10-32 screw(bolt) 1.2-1.5" long, a wingnut, a spacer, and the appropriate nut and put in that order onto the feedneck. Now it can be hand tightened without tools.
This post has been edited by Danny D: 06 June 2012 - 04:54 PM
#2 User is offline   Danny D
Posted 24 November 2010 - 10:30 PM
O-ring list updated!
If anyone would like to add problems or solutions they have had, post away!
#3 User is offline   DruidicRifleman
  • The Celtic Warrior who BBQ'd your village
Posted 28 November 2010 - 09:42 PM
Um? what would cause the board to go int UK only mode... i can't get mine to go FA
Current Set up SP1 with a Ninja 90/45 and Velocity And always rocking a Nerf sword
back Up A5 72/30 Pure energy JJ custom barrel
We Killed Humans FOR WE ARE BORG!!!!! RIP In the great PB field in the sky man YOU will BE MISSED!!
#4 User is offline   DruidicRifleman
Posted 03 December 2010 - 11:12 PM
should i hear a hiss when it shoots???
#5 User is offline   manoffew
Posted 10 December 2010 - 10:10 AM
Yes, the "exhaust" should be shooting out of the solenoid.
#6 User is offline   Kaps
Posted 18 December 2010 - 02:13 PM
So I have a problem, blew out my reg.
Can't find another Max Flow and I need one.
#7 User is offline   Danny D
Posted 18 December 2010 - 03:18 PM
You dont need a maxflo to operate the gun. Any reg operating between 100-200psi will work. 99% of the regs out there will work. The only one i think wont, is the PMI reg (min500psi). If you can repair the reg, it would be cheaper - take it apart, and replace whats needed.
http://www.paintball...0R%20Manual.pdf
Also seeing what hole air is coming from will determine what o-ring is blown. the top one is the pressure relief valve, which should only be venting when liquid co-2 gets in the reg, the other two indicate particular o-rings. SHould be easy to figure out.
#8 User is offline   Kaps
Posted 18 December 2010 - 03:51 PM
Well I want the Maxflow because itll work off of CO2 and sometimes thats all I have
Do you have any advice on what piece it may be that flew off of my reg?
#9 User is offline   Danny D
Posted 18 December 2010 - 04:00 PM
Its most likely the snap ring. Its the only peice that can fly off. Take apart the reg like the manual i posted says, and take a look at the parts list. Match the parts to what is there, and see if everything is there. Follow the instructions to lube and reassemble.
You probably wont need snap ring pliers to remove the bottom part, cause im guessing thats what flew off. Its a silver peice shaped as a c right at the top around the outside of the hole to adjust velocity.
Heres a vid:
http://www.youtube.c...h?v=-N7uOv04RYg
and use the manual to make sure all the parts are there. There is a great parts diagram in there.
Its easy, dont be scared to dissassemble the reg.
This post has been edited by Danny D: 18 December 2010 - 04:01 PM
#10 User is offline   Kaps
Posted 18 December 2010 - 04:04 PM
Found out what it was, it was the stop ring
Thanks for your help dude :)
Only problem, cant find it online :(
This post has been edited by Kaps: 18 December 2010 - 04:06 PM
#11 User is offline   Danny D
Posted 18 December 2010 - 04:26 PM
You can instead wrap a peice of wire around the base such that it prevents the cap from coming off. It should work just as well. But this peice isnt essential in the operation of the reg. For now wrap a peice of metal wire around the base and make sure the cap cannot come off. Then air it up to see if there are any leaks.
If you havent already, completely dissassemble the reg and lube the parts as per the video and the manual. You NEED to do this on a regular basis, just like the bolt. The reg needs to be lubed every 4 months, the bolt, every couple days. of play
This post has been edited by Danny D: 18 December 2010 - 04:27 PM
#12 User is offline   Kaps
Posted 18 December 2010 - 09:05 PM
this would happen to me, in the video he doesnt talk about getting into the velocity adjuster, thats where I need to go >.>
that was actually very easy, just unscrew like you would by adjusting the velocity. It will slowly go towards the edge the flip it over and push it out. Thats for the help
This post has been edited by Kaps: 18 December 2010 - 09:12 PM
#13 User is offline   Danny D
Posted 19 December 2010 - 01:28 AM
You cant get into the velocity adjuster. You would need specialized snap rings. Its not user servicable, and if theres a problem with it, you would need to take it in. In the velocity adjuster theres just one o-ring. That should not be the problem at all unless air is leaking from the velocity adjuster.
Update: New soloniod INFO!!!!
#14 User is offline   Kaps
Posted 19 December 2010 - 09:28 AM
The only way I got to it was because the stop ring was already gone after that just unscrew it out.
Its leaking from the bottom so I dunno where its at if I dont need the stop ring
Maybe an O ring
#15 User is offline   TheOneAndOnly
Posted 20 December 2010 - 04:28 PM
wow that is awesome, really really great guide B) thumbs up
#16 User is offline   Damianw43
Posted 11 January 2011 - 02:14 AM
how do you set up a sp-1 to shoot using co2?
#17 User is offline   Danny D
Posted 15 January 2011 - 01:35 PM
Set the dwell to co-2 setting. Consult your manual. For the stock board you need to disconnect the battery and reconnect holding the power button. If it flashes once its dwell is set for co-2, two flashes for hpa.
If your planning to use co-2 you will need to do the above, and a remote line or anti siphon valve would help a lot keeping your marker more efficient.
This post has been edited by Danny D: 15 January 2011 - 01:36 PM
#18 User is offline   jblaze56
Posted 06 February 2011 - 12:07 AM
My vibe is leaking from the bolt and i have tried all of your tips and i changed all of the o rings and lubed it. Any suggestions?
Description: every time i fire, it leaks for 5 seconds and then it stops sometimes but others i have to fire again to stop it.
#19 User is offline   Danny D
Posted 06 February 2011 - 01:25 PM
Check to see where the leak is coming from exactly. If the bolt is closed (forward) and leaking it may be the rear breech o-ring giving you the problem, or a blocked front banjo.
If the bolt is in the starting position (back) stick your finger down the breech while aired up and find out if you can plug the bolt face with your finger. If you cant plug the bolt face because the leaking air gives you resistance, then its coming from the bolt face. If you can plug your finger and feel air coming from AROUND the bolt, then the air is coming from around the bolt. Heres what it means:
Air coming from AROUND the bolt: The front part of the bolt is gouged deeply or the rear breech o-ring has failed and needs replacing.
Air is coming from the bolt face (inside the bolt hole): There is a gouge in the middle portion of the bolt, or both bolt stop orings and/or bolt sail o-ring needs replacing. Its most likely the bolt sail, or inside bolt stop o-rings.
Make sure there is enough lube before you change out any o-rings, and if the marker used to work on the previous chrono settings, do NOT change the velocity.
If your velocity was turned way down on purpose prior to the leak, you may have to increase it gradually. Having a regulator to test the pressure is reccommended as to not blow a soloniod. In any case dont adjust the velocity if you dont have to.
#20 User is offline   Mr.V
Posted 16 February 2011 - 07:40 AM
hello
just a small question
I use a blackheart board ( in the M249 mod :-) ) and an AKA Litre2+ regulator. it is set to 180psi
the problem is that the board's solenoid hisses a lot of air when firing (the gun cycles) but after several shots, the gun makes a "weak cycle" - where it firist only a "puf"
I will use a better battery next time I get to work on it, but do you have any idea what could cause it?
  • 4 Pages +
3 User(s) are reading this topic
