TechPB Forum: Dye Matrix Maintenance. New to the Matrix? - TechPB Forum
#1 User is offline   theultimatehero
Posted 30 September 2008 - 12:47 AM
Here are some videos i have put together specifically for the Dye section of TechPB.
Matrix Fuse Bolt Maintenance
Dye Hyper 2 Maintenance
Matrix Low Pressure Regulator Maintenance
Dye Matrix On/Off knob Maintenance
Dye UltraLight Frame Board Settings
More to come when my Vintage matrix shows up.
#2 User is offline   Rlpaintball
Posted 30 September 2008 - 08:10 PM
Fuse bolt maintenance link did not work.
Good work
#3 User is offline   theultimatehero
Posted 30 September 2008 - 09:49 PM
Thanks for the heads up. Fixed :D
#4 User is offline   Violent
Posted 30 September 2008 - 09:50 PM
Good work
Just take off the first chunk
http://www.&quot.com/;
Its right at the beginning of the link.
Never mind ultimate beat me hah. Nice work.
QUOTE (y2ksurvivor)
can I hyper fap with robo hands??
#5 User is offline   theFL@SH_69
Posted 01 October 2008 - 12:41 PM
great vids ultamate. :)
ECN/ ECA
#69
#6 User is offline   The M@N
Posted 01 October 2008 - 06:40 PM
Good information.
Fueled by hate, Driven by heart
#7 User is offline   Havok!Techno
Posted 06 October 2008 - 09:14 PM
sweet stuff def gonna clean my hyper 2 soon (how often should you do it?)
#8 User is offline   NB_Paintballer
Posted 07 October 2008 - 06:18 PM
Nice, Iv'e been watching your vids for a while now nopopallowed. They rock.
I do not have a signature in fear of the mighty Kittty.
#9 User is offline   theultimatehero
Posted 07 October 2008 - 09:41 PM
doesnt have to be very often. Dye recomends every 6 months at least. but it will vary a bit depending on how often you play and how much time you like to spend working on your gun.
#10 User is offline   left handed
  • Arms Dealer
Posted 07 October 2008 - 10:48 PM
Though it might be bad for my orings, when ever I encounter a leak, whether it be big or small, I relube everything. I mean bolt, LPR, and Hyper2.
I also do it after every day of play...sometimes... :mellow:
Read. Now.
RussianLegionFan#8
The only thing you need to wipe...is your ass.
Parents Don't Pay Clan
Speedball has nothing to do with how fast you shoot and everything to do with how fast you move. - Crawdaddy (PBF)
#11 User is offline   theultimatehero
Posted 08 October 2008 - 09:29 PM
That is a actually a good point.
If you experience bad drop off, inconsistent velocities, erratic cycling etc. It is a good idea to give your LPR and Inline a good cleaning to eliminate them as the cause. Not to mention if you do experience these problems the regs probably need the cleaning anyways.
