TechPB Forum: T8.1 extended mags? - TechPB Forum
T8.1 extended mags?
#1 User is offline   kalebach
  • banana hammock
Posted 24 October 2010 - 04:57 PM
Is there a magazine extender kit for the t8.1 mags and if so where can u get it?
I cant think of anything clever to make my sig
#2 User is offline   Eskimo
  • Member #: 666 ( Seriously )
Posted 24 October 2010 - 05:32 PM
Special Ops paintball used to sell them, as of right now they are no longer being produced, so you will have to buy them used off someone.
Citrus Connection
#3 User is offline   Special Ed
Posted 24 October 2010 - 06:40 PM
The SO mag extensions were for the old T8 or T9 mags.
(GTR+BMX+PB)xOCD=-$
YouTube Channel
http://www.youtube.c.../SpecialEdBMXPB
BST Feedback:
http://www.techpb.co...ndpost&p=495443
#4 User is offline   lashcoin
  • Chicken in the coop!!!
Posted 11 November 2010 - 10:24 PM
Thought I'd Necro post this, but Spec Ops still sells them.
http://shop.specialo...-17-rd-kit.html
Purple CCI T-Stock
My Feedback 9/0/0
#5 User is offline   TK-421
  • Me So Horny! :D
Posted 11 November 2010 - 10:29 PM
As posted above, Spec-Ops sells them, and they work for the T8, T8.1, T9, and T9.1, but I do not believe the extensions are FS compatible. However, you might still be able to put 8 FS rounds in the original mag part, but I don't know if they'd feed well, as I don't have my hands on one.
#6 User is offline   NoLimitsOnLife
  • Patience is a Virtue, and my board is broken
Posted 10 December 2010 - 07:11 AM
these only work for the T8 and T9. when you order it all you get is the extended mag section, 2 long screws and a spring. there are 2 screws on the bottom of your own t8/t9 mag that the T8.1/T9.1 doesn't have. you unscrew those to remove the bottom cap and remove the stock spring with the provided spring and screw on the extender kit. thats all there is to it. because the T8.1/T9.1 mags don't have those 2 screws the kit is incompatible
Setup: System X NME LE, Dye Rotor, Guerrilla Air 88/4500 Myth G2
MARYLAND BALLERS FTW
Feedback:9/0/1
