TechPB Forum: Quest Bore Size - TechPB Forum
Quest Bore Size
#1 User is offline   Dust
  • Newbie On the Block
Posted 27 October 2010 - 04:30 PM
ÉWhat size is the bore that the quest comes with?
#2 User is offline   OOG671
Posted 27 October 2010 - 07:37 PM
Quest came with .689 and .696 2 piece 007 barrels when they first came out. Some 2007 models came with a .693 1 piece.
If you are buying a Critical 07 Quest I believe you can request for a barrel size if you speak to the folks directly at Critical Paintball.
Also feel free to visit the FEP Quest owners thread in my sig. There's a lot of info there and if you post questions there you're likely to get faster responses due to the traffic we have there.
Hope you get a Quest it's a good shooter.
Muppet #72, Christian Baller
