TechPB Forum: Smart Parts SP1 vs GoG G1 - TechPB Forum
#1 User is offline   Rollieelmo
Posted 02 February 2011 - 11:32 PM
Is the G1 a cozmetically improved SP1, a performence improved SP1, or an overall improved SP1. Is Mike going to review the G1 and eNVy?
Rockin' Cocks Revolution
#2 User is offline   IhasAcellular
  • You will never be 9 headbands agg.
  • Group: Chat Moderator
Posted 02 February 2011 - 11:35 PM
I believe it comes with the blackheart board, and breach stock....so I'd say its a performance improved sp1
#3 User is offline   {Pb}Atracin
  • Bow Chicka Wow Wow
Posted 02 February 2011 - 11:37 PM
I think the G1 is an improved SP1. You have the ability to choose what feedneck style you want, comes with a stock in box and a longer barrel (with the SP1, you had another version called the Tactical Edition), but you get all of these options in box.
The G1 doesnt come with an Blackheart board (if I'm not mistaken):
Quote
Features
* 11 bps ( upgradable to 25+ with QEV and Board )
Thats quoted from ansgear.
This post has been edited by {Pb}Atracin: 02 February 2011 - 11:38 PM
SPEHSS MAHREENS
Lick it.
#4 User is offline   Rollieelmo
Posted 02 February 2011 - 11:40 PM
So you would have to buy a new board? Then why is the gun priced at 250 when the SP1 was 170?
#5 User is offline   Zombie Afroshot
  • Bwaaah
Posted 02 February 2011 - 11:42 PM
It has a new reg, new breech, stock, longer barrel..
Feedback4/0/0
#6 User is offline   ThunderLights
  • VIce is in the shop
Posted 03 February 2011 - 07:01 AM
omfg guys... the G1 comes with a stainless steal screw kit, different reg cover, 14'' barrel, hard case, stock, no wedge and select feed. now decide for yourself if thats worth it.
all of them are useless upgrades except for the 14'' barrel and screw kit IMO and the hard case :)
This post has been edited by ThunderLights: 03 February 2011 - 07:01 AM
#7 User is offline   GoldenElite0
Posted 03 February 2011 - 08:03 AM
The stainless steel screws are the best edition to the G1, any SP1 owner will tell you this.
This post has been edited by GoldenElite0: 03 February 2011 - 08:04 AM
#8 User is offline   brycelarson
  • Show me the Data!
Posted 03 February 2011 - 08:06 AM
cosmetics have changed a touch - nothing significant.
performance? nope, semi only board stock. It does have the eye channels milled in the body - but until we know how much the new board and eyes cost we don't know if this is an improvement.
so, not improved - just re-released.
#9 User is offline   Hebiki
  • Elite Member
Posted 03 February 2011 - 01:24 PM
any ideas on when the new board/eyes will be released?
#10 User is offline   IhasAcellular
Posted 03 February 2011 - 01:33 PM
Maby thats what I got confused with. My apologies sirs!
Quote
Available in UK - semi auto or US field adjustable - semi auto, fully auto and 3 shot burst also PSP & BillyBall modes as standard !!
It appears that its not a semi only board btw.
This post has been edited by IhasAcellular: 03 February 2011 - 01:36 PM
#11 User is offline   Crashkt90
Posted 03 February 2011 - 01:38 PM
I wouldnt mind getting a vibe..
Reverse Drop Forward Gloss Black Modified Stock Class Phantom
#12 User is offline   PaintballWill
  • Team Coco
Posted 03 February 2011 - 01:43 PM
is there a way to get the right or left feedneck to be vertical?
#13 User is offline   Weigel21
Posted 03 February 2011 - 05:22 PM
Yes, it's able to be any of the three. There's a 45* hopper adapter included in case you choose not to run with a center feed setup.
#14 User is offline   xero
  • Don't divide by me......
Posted 04 February 2011 - 10:52 PM
Ok, never owned an sp1, but wanted one for a long, long time.
Was ready to get an sp1, then saw the g1. After handling it, I decided on it, and purchased today. number 00163 to be exact.
Difference, as far as I know, from the sp1 to the g1, are:
longer barrel: 14 inch vs whatever it came with before.
Adjustable feed neck: either right, left, or center feed. Also comes with elbow adaptor.
-it is also important to note that the left/right feed as well as the center feed, are made of plastic painted to look like the metal of the marker.
no battery wiggle
Both a stock and a standard backplate
-Important to note that the gun WILL NOT fit into the box with the stock attached. Even with the buttplate of the stock removed, it will not fit, even if you mod the foam inside.
The manual is now on CD-rom instead of a paper manual.
It says G! on the side, I imagine where it used to say SP1
To remove the stock, you must remove the stock plate adaptor. You have to do this every time you put it into the case. Pain in the ass.
It comes with a Smart Parts Barrel Sock. Posted Image
The case is of high quality. Very high quality. High impact plastic, with a very dense foam inside. With the box my g3 came in, I can push my finger hard enough into it to feel the box on the bottom. Not happening with this foam.
The board, from what my pro-shop says, is coming extremly soon. He says that he is hoping to have it on Monday, and if not then, it will be coming in the next "couple of weeks".
The price for the board is 69.99.
And lastly:
The battery does not rattle.
Overall, I am pleased with my purchase. I didn't think to bring my tank, so have not put paint downrange. Full review w/ unboxing coming in the next few days!
View Postjdatkinsn, on 15 February 2011 - 05:16 PM, said:
"Forgive the shitty pictures of my brand new high-end 2011 model paintball gun I took in front of my massive televisions with my current-gen iPhone, but my parents took my professional quality camera with them on a vacation halfway around the world. MY LIFE IS DIFFICULT."
#15 User is offline   Weigel21
Posted 05 February 2011 - 12:09 AM
no battery wiggle
And lastly:
I see it online for $64.95 on Actionvillage and firstcall paintball. However, AV looks to be a preorder.
#16 User is offline   cavemag
  • R.I.P Borg.
Posted 05 February 2011 - 12:12 AM
From what i've seen GoG has learned from their Smart Parts days mistakes and are starting to put more fit and finish into their markers.
