TechPB Forum: NT break in test - TechPB Forum
NT break in test
#1 User is offline   brycelarson
  • Show me the Data!
Posted 10 February 2011 - 09:27 PM
here you go kids:
https://spreadsheets...=en&output=html
#2 User is offline   cockerpunk
  • All the Dudes
Posted 10 February 2011 - 10:03 PM
vid is up -
#3 User is offline   Eskimo
  • Member #: 666 ( Seriously )
Posted 10 February 2011 - 10:20 PM
wait so what happened on clean 2? lol. Standard deviation went all over the place aha
it seemed to break itself in over 4 cases then when you cleaned it, it went back up then continued down again.
Maybe it gets better the more you use it.
This post has been edited by Eskimo: 10 February 2011 - 10:21 PM
Citrus Connection
#4 User is offline   The_Economist
  • It's business time.
Posted 10 February 2011 - 10:24 PM
Maybe it never gets better. That data sure doesn't indicate a trend line to me.
#5 User is offline   Eskimo
Posted 10 February 2011 - 10:33 PM
first bit declines, then after the clean it spiked, then goes down. wish I could have seen the SD on the next 3 cases.
Citrus Connection
#6 User is offline   cockerpunk
  • All the Dudes
Posted 11 February 2011 - 01:31 AM
cleaning seems to add more variability then usage ... what does that mean?
#7 User is offline   KellyP
  • Air Force
Posted 11 February 2011 - 01:34 AM
Hm, not a bad amount of tests, though the results are quite confusing show no surefire results.
Pm me if your interested in a sig
Proud Air Force Paintballer
#8 User is offline   Lord Odin
  • 3 may keep a secret if 2 of them are dead
Posted 11 February 2011 - 02:18 AM
I'd say Clean 2 was the only outlier. All the others seem to be pretty much within tolerances. If you look at the data, all of it jumps around from 6-8 fps in SD. That seems pretty normal to me.
What I'd like to know is why such high SD's? Where the averages used with paintballs instead of Reballs? I've yet to experience such high numbers with Reballs unless there was a mechanical problem.
#9 User is offline   brycelarson
  • Show me the Data!
Posted 11 February 2011 - 07:47 AM
All chrono data is with real paint - and SDs of 6-8 are in what I would consider the normal range.
#10 User is offline   LieutenantDan
Posted 11 February 2011 - 11:40 AM
Soooo in other words we're more confused now than we were before?
My Feedback +5|-0
To HELL with georgia
#11 User is offline   iceman6
Posted 11 February 2011 - 12:02 PM
Never clean it! kidding... kind of. To bad this test wasn't as straight forward as the G6R. That was just to easy...
#12 User is offline   The_Economist
Posted 11 February 2011 - 01:04 PM
I'm not confused, I have been thinking for a while now that break-in periods are a myth.
#13 User is offline   Schuppert3
  • Respect the BBN
Posted 13 February 2011 - 11:01 AM
yeah i always thought break in periods did not do much
TechPB-Mike, on 06 August 2011 - 07:15 PM, said:
Feedback +5/-0
Mod App
#14 User is offline   Lain
Posted 20 March 2011 - 06:39 AM
I wonder if the "brake in" is more of a psychological nature then true brake in of the marker.
In the line of, people need to get used to and learn to use the marker.
And after you have tinkered with it a time, tuned it, adjusted it just right, it just feels that much better?
Or to ask in another way, what on a marker should have a need for a brake in?
#15 User is offline   pb101
Posted 21 March 2011 - 04:15 PM
They say the o-rings and stuff. Truth is I have bought a brand new cci phantom, put on a barrel kit for a nice tight match, and I've gotten the best numbers you can get over the chrono. That alone to me proves there is no such thing as a break in period.
#16 User is offline   RatDragon
Posted 22 March 2011 - 05:00 PM
Interesting stuff guys. I need to read the rest of these tests before I can make any semblance of meaningful contributions.
"Just remember kiddies: Cheaters don't just suck, they also swallow too!"-Tyger
"A Player's Personal Preference is what determines what he/she wants on a Marker, not what other people think that the Player should have on the marker." EvilFingers
Support Grassroots
#17 User is offline   crazylot
Posted 07 July 2011 - 12:55 PM
wait... so this test means that the NT11 break in dosent effect the FPS over time or it will always fluctuate like that even after many cases?
#18 User is offline   brycelarson
  • Show me the Data!
Posted 07 July 2011 - 01:22 PM
based on our testing cleaning the gun has as much or more impact as break in.
