Is there a pump kit you can buy for the azodin kaos? Because most likely i will be selling my kaos, and i thought if i ever want a pump i could just turn it into a pump and use it every now and then so that i wouldnt be wasting money if i decided to buy a pump down the road.
Azodin Kaos pump kit?
#3
Posted 13 February 2011 - 02:29 PM
Nope, I think you are confusing these with autocockers. Autocockers are basically like Pumps right out of the box. The only reason why there is a KP is because the Kaos is an mechanical marker. But most of their mechanical stuff is internal not external like an Cocker. The reason why you can do a cocker so easy is because you have a primin rod and you can easily just swap that out. While if you were to try to make a Kaos into a pump you would have to do a lot of custom milling and honestly would not be worth the hassle.
OWNER OF AN DUST BLACK CCM T2, ASHES EGO 11, AND VICIOUS GEO 2!!!!!!!!!
#4
Posted 13 February 2011 - 03:16 PM
You could turn it into a spump, but at the end of the day I'd probably be sketchy work that won't rival an actual AKP, just sell and buy an AKP
