From Tiberius Arms -
Paintball's First Sniper Round
Utilizing a combination of aerodynamic shape and fin stabilization technology, First Strike Projectiles maintain their velocity longer. The result is 50% greater range and unrivaled accuracy. Finally players have an alternative to accuracy by volume or backspin gimmicks that simply change trajectory. Become one of the first true paintball snipers with first strike. First Strike conversion kits are available for all Tiberius Arms markers.
Test conducted by firing 5 paintballs and 5 First Strike Projectiles from the same marker at the same velocity (300fps) from a bench mount at a 45 degree angle
Max Range of a standard paintball - 337 feet
Max Range of First Strike Projectile: 510 feet
Test conducted by firing 15 standard paintballs and 15 first strike projectiles from the same marker, on a bench mount, at the same velocity (290fps) on an indoor range at 100 feet.
Sign In
Register
MultiQuote
