TechPB Forum: Axe dosnt work with prophecy ltd - TechPB Forum
#1 User is offline   Thizzalot
  Posted 11 October 2011 - 10:59 PM
So I just got my Axe and a new prophecy LTD and the axe is to quiet to use the sounds mode. I have the sound set a high as it can go. HELP
#2 User is offline   drunkenpriest
  • I relax 8 days a week.
Posted 12 October 2011 - 12:43 AM
that weird i hava mini with a too and it works
#3 User is offline   misterkyle
Posted 21 December 2011 - 11:27 PM
change settings on prophecy
#4 User is offline   littleloopy15
Posted 21 December 2011 - 11:31 PM
just scream every time you want to shoot :dodgy: haahaha
but yeah are you sure that you have the prophecy all the way up? my friends use their prophecys and axes and they work fine.
Feedback 17/0/0
#5 User is offline   Jarz
Posted 22 December 2011 - 11:53 AM
My Z2 (and sound activated Invert TOO) work fine with my Axe...
#6 User is offline   Eskimo
  • Member #: 666 ( Seriously )
Posted 22 December 2011 - 12:10 PM
use has manuel?
Reads das manuel
you dont?
http://www.paintball...ual_w_cover.pdf
Quote
The Prophecy Loader is defaulted to Sound Activation. Simply turn the
Prophecy Loader on and check that the loader is being activated by the sound
of your marker. If necessary you can adjust the sound sensitivity level to match
your markers sound signature. See the Board Function section for more details
on changing the sensitivity.
Quote
Sound Sensitivity - 6 levels of adjustment, level (1) being the least sensitive and
level (6) being the most sensitive.
Note:
It is better to have the microphone setting less sensitive and still able to detect
the marker firing. Do not set it to 6 if setting 2 detects the marker firing
correctly. Only use a higher setting if the lower setting does not detect the
marker firing.
Page 15 describes how to change the settings on your loader.
make sure to always set it when shooting paint physically at the range.
and most people can get their loader to sound activate at setting 3
not sure why yours wont work.
This post has been edited by Eskimo: 22 December 2011 - 12:11 PM
Citrus Connection
#7 User is offline   DrewaV
Posted 23 December 2011 - 12:39 AM
View PostEskimo, on 22 December 2011 - 12:10 PM, said:
use has manuel?
Reads das manuel
you dont?
Quote
Quote
Note:
marker firing.
Lolz to this thread. All you do bud is up the mic volume look at the manual above.
