TechPB Forum: Etek 3 vs Etha - TechPB Forum
Etek 3 vs Etha
#1 User is offline   ZachPB
Posted 16 October 2011 - 11:50 PM
Should I sell my Etek 3 LT for the Etha when it comes out? I posted up a forum(http://www.techpb.co...howtopic=168254) about the Etha's specs after reading the specs of the Etha do you think that the Etek is better then the Etha? Need help deciding!
#2 User is offline   Iktinos
Posted 17 October 2011 - 10:44 AM
Question: Do you like shooting a spool valve? If yes, then do it. If no, then don't. If you don't know, try a spool valve first so you don't make the mistake of selling something that you do like, and getting something that you may not like.
#3 User is offline   ZachPB
Posted 17 October 2011 - 07:32 PM
I used a proto slg UL that was my first gun and it was alright and I want to shoot something like a ego and I got an etek I like it but the bolt it loud and the barrel is shit I have a 2011 POPS ASA on it and need money for a better barrel and a new bolt because the stock bolt is loud
#4 User is offline   Iktinos
Posted 17 October 2011 - 11:07 PM
Changing your bolt isn't really going to quiet it down much. That's the thing with Ego's, and Etek's, they are loud. You can quiet it down a bit with tuning, and a good barrel with porting.
#5 User is offline   ZachPB
Posted 18 October 2011 - 06:04 PM
I am thinking of getting the Dye Carbon Fiber Boomstick barrel
#6 User is offline   Iktinos
Posted 19 October 2011 - 10:27 AM
I have no idea what the porting is like on the newest DYE barrels, but I am sure that somewhere there is a noise chart, talking about one marker, chronoed to a specific velocity, same paint, different barrels, and what they sound like.
#7 User is offline   gnarlyeggs
Posted 19 October 2011 - 10:40 AM
I'm not sure. Wait till the Etha is reviewed, it's not like you will be making a huge leap. I think the Etha was priced lower for a reason though.
Urban Digicamo Etek 3 LT - Digicamo Tippmann A5
CP 2 piece .682 and .685, Empire Prophecy Z2, Ninja 68/4500
Feedback +2
#8 User is offline   ZachPB
Posted 19 October 2011 - 09:37 PM
After looking at the specs of the gun it doesn't really look that great
#9 User is offline   buzz-jahat
Posted 20 October 2011 - 10:14 AM
etha would be great for a budget baller. it has everything a player needs...of course when you already have something similar ( i.e Etek...im not talking about technicals here)... maybe an upgrade is a better choice... Ego10 or geo 2 maybe...
PE SL Family, Maximum Custom Jersey, Petro Edge, Putra Paintball Park Malaysia
#10 User is offline   JRigs24
  • Etek
Posted 03 November 2011 - 10:53 AM
No. Etek 3 is a way better gun
Etek3 AM
Dye Rotor
Ninja 68/4500
Team Dynasty
#11 User is offline   BDidz
Posted 21 November 2011 - 09:28 PM
How would you have any idea if the gun has not been released yet...
And its kinda early to do a "should i get this gun" thred if one of the gunsw you are looking at has not been reveiwed or ever released.
