TechPB Forum: Shaft 4 on Etha - TechPB Forum
Shaft 4 on Etha
#1 User is offline   enginerd
Posted 22 February 2012 - 06:02 PM
I just picked up a new Shaft 4 back for the Etha and I hadn't seen any pictures showing one with a stock Etha tip, so here are a couple for curious minds.
The anodization texture is consistent and the outside diameters mate very well, so if it were black, it would be a seamless fit with the stock marker.
#2 User is offline   BDidz
Posted 22 February 2012 - 07:09 PM
Nice lookin gun man
#3 User is offline   redliness
Posted 22 February 2012 - 08:28 PM
man i like the look of that silver back! and the shaft 4 black backs/front are a little darker or glossier than stock etha.(the ones i got anyway)
#4 User is offline   enginerd
Posted 22 February 2012 - 08:52 PM
Does the shaft 4 front change the sound at all? I'm just curious because it has about twice the porting.
#5 User is offline   redliness
Posted 23 February 2012 - 01:54 PM
ive only shot it with the 16" tip so i dont know.<br><br>but its generally accepted that more porting = quieter <br>
#6 User is offline   littleloopy15
Posted 23 February 2012 - 02:16 PM
there are two "black" shaft4 barrels you can get. The actual black and the ashes. It looks like you got the ashes, but I can be wrong.
Feedback 17/0/0
