TechPB Forum: End All Thread to: I need a speedball marker for $XXX - TechPB Forum
End All Thread to: I need a speedball marker for $XXX Just want these all compiled.
#1 User is offline   WiscoBaller
Posted 15 March 2012 - 11:36 PM
First, I am not familiar with every gun I will be listing. I have shot Egos, DM's PM's, Mini's, Axes, ETC. I have not shot the new rail/reflex from Proto. I will attempt to cover most things.
<100 Range:
Save your money, and play with the rental guns. You will regret anything you buy new for under 100.
<200 Range:
Azodin Blitz:
MSRP: 169.99
The Azodin Blitz paintball gun is a great mid level paintball gun for beginner to intermediate paintball players. The fully electric Azodin Blitz is a great gun for a paintball player to start with and be competitive on the field. The Azodin Blitz comes stock with multiple firing modes and can shoot up to about 14-15 balls per second.
-Blow Back
-Cocker Threaded
Used: 100
Dangerous Powers E1:
MSRP: 189.99
The all new Dangerous Power E1 paintball gun is the hottest new paintball gun from Dangerous Power. With a competitive price and compilation of features, the Dangerous Power E1 is a great paintball gun for any beginning to intermediate paintball player who wants to have a competitive paintball gun.
Utilizing the G3 bolt and internals, the Dangerous Power E1 is build off of an established platform that has been tested and proved to work great.
-Spool
-Cocker Threaded
Used: 100
GOG Envy:
MSRP: 199.99
Check out the all new eNVy GoG paintball gun which is one of the latest releases in the GoG paintball gun lineup. The all new GOG Envy is built off of a tried and true platform with great upgrade-ability. Get the Envy if you want something reliable, affordable and effective. The eNVy series GoG paintball gun has been designed for the entry level and field rental players. Built using the latest technology, the Envy will hold its own with even the best guns in paintball.
-Spool
-GOG (Smart Parts) Threaded
Used: 75
<300 Range:
Proto Rail:
MSRP: 299.99
Taking over the field, the Proto Rail™ is your stepping stone to greatness. High-end performance in a durable and reliable setup, the Proto Rail™ is for the serious competitor. Featuring Boost™ Forward Technology, giving you a cushioned push on the ball and delayed bolt speed for increased air efficiency and high rate of fire.
-Spool
-Cocker Threaded
Used: 200
GOG Extcy:
MSRP: 249.99
The eXTCY line of GoG paintball guns is specifically designed for any intermediate paintball player who wants the most up-to-date technology without spending a fortune. You will notice that the GoG eXTCY has a light weight design that is very durable and can take some serious abuse on the field. The eXTCH GoG paintball gun is built to last for a long time with even the toughest and most abusive players.
-Spool
Used: 175
Azodin Zenith:
MSRP: 249.99
The Azodin Zenith paintball gun is a great quality gun that is very durable and built well. The Azodin Zenith is a very well crafted gun and works well for any beginning to intermediate paintball player. The Zenith is fairly universal and will work for scenario, woodsball, rec play, or beginner tournaments.
-Blow Back
-Cocker Threaded
Used: 150
Dangerous Power G4
MSRP: 299.99
The Dangerous Power G4 paintball gun is finally here! With the long lived success of the G3 series paintball guns, it was only a matter of time before the Dangerous Power G4 would hit the market. The Dangerous Power G4 paintball gun has all of the necessary tournament features and performance upgrades.
-Spool
-Cocker Threaded
Used: 200
<400 Range:
(This used to not exist, but being the Etha and Mini exist here, I will list them)
Invert Mini:
MSRP: 325.99
THE Empire MINI Fast, light, tight, and ... tiny! But more impressive than the size and feel, the MINI boasts some of the hottest new technology to hit the paintball industry in years! If you’re ready to experience the next stage in paintball evolution, grab a MINI and step ahead. Weighing in under 2 lbs (including barrel, ASA, 9volt battery and regulator) the Empire Mini™ might be THE Lightest & Tightest electronic marker available.
-Inline Poppit
-Cocker Threaded
Used: 200
Mokal Aura:
MSRP: 329.99
The Aura has all the air lines machined in the handle eliminated those bulky and leak prone macro fittings. The electronic controls and status leds are conveniently located in the foregip. The inline bolt system is completely removable from the back of the marker.
-Spool
-Cocker Threaded
Used: 200
Planet Eclipse Etha:
MSRP: 399.99
The Etha has been designed and constructed with a modular approach in mind and incorporates mounting points around the body for the addition of accessories and upgrades to be bolted directly to the marker. It should make for economical expansion of the Etha for those looking to build upon this exciting new platform.
-Pull Poppit Spool
-Cocker Threaded
Used: 325
<500 Range:
Empire Axe:
MSRP: 459.99
The Empire Axe is what you need to cut your way through the competition! When you grab the all new Empire Axe paintball gun you will feel a gun built for a real man. The Empire Axe is an Invert Mini on steroids and is bigger and badder than ever.
-Inline Poppit
-Cocker Threaded
Used: 325
Etek3LT:
MSRP: 499.99
Check out the new Planet Eclipse Etek 3 paintball gun. This is one of the best mid price paintball guns on the market with performance of the high end markers. The new Etek 3 gun is very light weight and has many similar features to the all new Ego Ten. Order your Etek 3 so you can be one of the first people to dominate the field with this paintball gun. LT includes composite frame, eye covers, and feedneck.
-Poppit
-Cocker Threaded
Used: 350
Proto Reflex Rail:
MSRP: 499.99
The all new Proto Reflex Rail paintball gun is a high-end performing marker that delivers a serious bang fro your buck. Operating at only 145 PSI, the Proto Reflex Rail fuse bolt is easy on even the most brittle paintballs. The small and lightweight Hyper 3 regulator is stock on the 2012 Proto Reflex Rail and will supply a steady flow of air to ensure you have great consistency from this paintball marker.
-Spool Valve
-Cocker Threaded
Used: 300
Dangerous Power FX:
MSRP: 499.99
The long awaited FX finally takes a stand and delivers dangerous and cutting edge technology to the Fusion series. The Fusion X takes a prideful stand and fierce introduction for the new decade! Through intricate design and development, the Fusion series conjures powerful attributes making it a new class of Dangerous Power markers. From superior quality, the FXs newly designed internals ensure dominating performance. The slim striker systems compact performance aims to deliver efficiency and accuracy. The lightweight body and internals ensures quick mobility for a fast response time. The OLED micro-switch board is capable of programming tournament modes and much more. The Fusion X grasps the balance of raw power, accuracy, and mobility all at an affordable price.
-Poppit
-Cocker Threaded
Used: 325
<750 Range:
MacDev Drone DX:
MSRP: 549.99
The MacDev Drone DX is a high quality, light weight gun that offers premium features for a fraction of the price. Buy the MacDev Drone DX and upgrade your game.
-Spool
-Cocker Threaded
Used: 425
Etek3AM:
MSRP: 599.99
Check out the new Planet Eclipse Etek 3 paintball gun. This is one of the best mid price paintball guns on the market with performance of the high end markers. The new Etek 3 gun is very light weight and has many similar features to the all new Ego Ten. Order your Etek 3 so you can be one of the first people to dominate the field with this paintball gun. AM Includes metal frame, eye covers, and feedneck.
-Poppit
-Cocker Threaded
Used: 400
<1000 Range:
Vanguard Creed:
MSRP: 799.99
The Creed is the culmination of three years research & development of air flow dynamics and electropneumatic control systems. We have created from the ground up of our own unique solenoid design and software systems. It is brought together with a vicious light weight package, that leaves no player wanting more, a marker truly made "FOR THE GUNFIGHT"
-Poppit
-Cocker Threaded
Used: 500
Dangerous Power Rev-i:
MSRP: 849.99
The Dangerous Power Rev-I have two unique features which differentiate this gun from most other guns on the market. . The Dangerous Power Rev-I has a gauge built into the back of the gun. This helps you to easily set and monitor the regulator pressure of your paintball gun.
The other unique feature of the Dangerous Power Rev-I is the cut out bolt design. The Dangerous Power Rev-i has multiple windows cutout so you can actually see the inner workings of the paintball gun itself.
-Spool
-Cocker Threaded
Used: 500
Bob Long G6R:
MSRP: 999.99
The Bob Long G6R utilizes the popular stacked tube design from the original Intimidator series paintball guns. The Bob Long Intimidator has no external hoses or macro line. This ensures less problems with the gun and makes the Bob Long G6R Intimidator one of the most reasonably priced and reliable guns in the lineup.
-Poppit
-Cocker Threaded
Used: 650
<1500 Range:
Vanguard Demon:
MSRP: 1049.99
The Demon has been created after years of research and development. Gas through regulator and Patented Bolt design. The bolt is designed for high efficiency rates, smoother shots and lower maintenance.
-Spool
-Cocker Threaded
Used: 900
Dye DM:
MSRP: 1299.99
The DM is the most advanced and famed gun in the always popular Dye line of paintball guns. The DM series guns have led many professional teams to the podium including the Ironmen and Tampa Bay Damage.
If you are looking for a great paintball gun that is smooth, quiet and can shoot the most fragile paintballs on the market, then the Dye DM paintball gun is exactly what you need. The DM is the only spool with an LPR.
-Spool
-Cocker Threaded
Planet Eclipse Geo:
MSRP: 1249.99
The primary changes combined with the core Geo and Planet Eclipse values take the new Geo to the next level. To make it one of the smoothest, quietest, efficient, well balanced, lightest, reliable spool valve markers on sale today, and to nail it firmly into upper echelons of high-end paintball equipment.
-Spool
-Cocker Threaded
Used: 700
Planet Eclipse Ego:
MSRP: 1249.99
The Ego has been developed and created with the soul intention of giving the modern player the things they most desire in a modern paintball marker. A smoother shot. A quieter sound signature. Outstanding Efficiency. Unparalleled reliability. Simplicity. Industry-Leading Customer Service. Ergonomics. And built-in User Adjustability and choice. All from a company that whatever the situation, whatever the occasion, will always have your back.
-Poppit
-Cocker Threaded
Used: 800
Bob Long Victory:
MSRP: 1249.99
With all of the same great features from the previous version Victory guns, the Bob Long Victory has some amazing milling and looks better than ever before.
-Inline Poppit
-Cocker Threaded
Used: 650
Macdev Clone GT:
MSRP: 1399.99
(Updated when info comes out)
-Spool
-Cocker Threaded
Used: None (not released yet)
DLX Luxe:
MSRP: 1499.99
The Luxe retains all the best features from its heritage: multi-league firing modes, sleek ergonomic design, joystick controlled easy voice-navigation menu system, unbeatably fast access to both the bolt and valve for fast cleaning and maintenance, Freak adaptable barrel technology, 4-point adjustable trigger, angled ball detents, hose and tube free integrated air design, and red-carpet customer service befitting a true luxury paintball marker.
-Spool
Used: 1000
This post has been edited by WiscoBaller: 20 March 2012 - 05:27 PM
The Hooligans Paintball Team
Bob Long Ripper FST
#2 User is offline   drunkenpriest
  • I relax 8 days a week.
Posted 15 March 2012 - 11:41 PM
first and cool
This post has been edited by drunkenpriest: 15 March 2012 - 11:42 PM
#3 User is offline   pb=life
  • I like penguins
Posted 15 March 2012 - 11:59 PM
Add in used guns
#4 User is offline   legitpro808
  • Living the HI life
Posted 16 March 2012 - 03:30 AM
the reflex is a spool
Axe Conglomerate v3
Repping the 808 State! Oahu Grown
#5 User is offline   MMMerc
Posted 16 March 2012 - 09:53 AM
View Postpb=life, on 15 March 2012 - 11:59 PM, said:
Add in used guns
:tup:
#6 User is offline   XxJellyFilledxX
  • dat fity snake
Posted 16 March 2012 - 11:14 AM
Add in used guns
:tup:
:tup: :tup:
This post has been edited by XxJellyFilledxX: 16 March 2012 - 11:14 AM
#7 User is offline   3o5 Paintball
  • RAWR
Posted 16 March 2012 - 11:36 AM
this is good bro, nice detailing
Rockin the G3
#8 User is offline   livestrong 917
Posted 16 March 2012 - 12:28 PM
:tup: nice write up!
#9 User is offline   zuchaka
Posted 16 March 2012 - 12:36 PM
thx for putting that together in one place :)
#10 User is offline   Card
Posted 16 March 2012 - 02:07 PM
As the guy stated above, the reflex is a spool and not a poppit! Other than that good writeup!
Woot Bagel!
#11 User is offline   sLick415
Posted 16 March 2012 - 02:14 PM
:tup: for the write up! But the title doesn't really shout, "Hey! Looking for a new marker?! Click here!!"
#12 User is offline   The Bacon Man
Posted 16 March 2012 - 02:32 PM
Add in used guns
:tup:
:tup: :tup:
#13 User is offline   TallThing
  • Left Blank Unintentionally...
Posted 17 March 2012 - 12:31 PM
The Kaos is worth $90. Just saying.
If life gives you melons... you may be dyslexic.
#14 User is offline   WiscoBaller
Posted 17 March 2012 - 10:18 PM
I don't think so, as it doesn't shoot that much better than a tippmann, and it will be upgraded quickly.
Guys, I want pictures in the thread. If you consent to me posting them here, send me a PM with the link to your image (photobucket or imageshack) and I will post it up here, one picture per marker. I will try to post used prices for these as I see them. I do not want arguements to break out over x vs y, or z is better than a because...
This is simply here to help people find markers to research in the respective price ranges.
Bob Long Ripper FST
#15 User is offline   WiscoBaller
Posted 17 March 2012 - 10:44 PM
Add in used guns
Used prices added
Bob Long Ripper FST
#16 User is offline   NPpballer
  • I'm Rick James, BITCH!
Posted 17 March 2012 - 10:49 PM
/opinion and don't waste your time adding used guns. There's WAY to many to even make sense of.
#17 User is offline   The Knife Crazy
  • No Pain No Game
Posted 17 March 2012 - 11:17 PM
this is really good and helpful...this should be stickied!!!
Don't hate on my G4!
Current Setup:
Empire Axe in Gun Metal Grey
Dye Rotor
Ninja 50/4500
#18 User is offline   NJC
  • pumper
Posted 18 March 2012 - 11:08 AM
agreed, but holy shit long write up.
i also think you should have some form of separation between the price points and used price points because it is a little hard to find what you are looking for
This post has been edited by NJC: 18 March 2012 - 11:09 AM
View Post-ORaNGe-, on 18 November 2011 - 04:24 PM, said:
*Waits to get hit*
#19 User is offline   TallThing
Posted 18 March 2012 - 09:56 PM
Not trying to start an argument, but you're saying that, because a Kaos doesn't shoot that much better than a 98, it should be excluded. It is well worth the money as, it shoots better (even if just a little better), has an easier disassembly, and its $60 cheaper than a 98. It is worth putting in this topic. I think that it deserves coming in the <100 section.
#20 User is offline   Arjay
Posted 18 March 2012 - 09:57 PM
Cool writeup, deserves a sticky in my opinion!
Feedback: 2/0/0
