TechPB Forum: My journey with the rainmaker - TechPB Forum
#1 User is offline   Klub
  • i haz a pickle
Posted 17 April 2012 - 07:20 PM
So, I bought a rainmaker. I expected it to come in in functioning order, but insted I got a pile of shit.
The board is disconnected to the 4 way, no battery harness, and no shroud. I figure I may as well finish what the guy started.
Feel free to help me out along my endever, as I will probobly need it
Picture at the start
This will be my journey through which I hope to make a functioning rainmaker
Day 1: Rainmaker arrives, in pieces. I believe this is how the wiring goes, I need to buy a 9 volt batterey harness. Can anybody verify if this is correct?
#2 User is offline   Original Gangsta
  • My name is a lie.
Posted 17 April 2012 - 08:25 PM
I don't even...
Honestly, I would try MCB over TechPB for something like this.
View PostRealtorTommy, on 15 June 2011 - 08:30 AM, said:
#3 User is offline   Klub
  • i haz a pickle
Posted 17 April 2012 - 08:44 PM
Yea, I know. but I might as well post it here too.
#4 User is offline   Myrkul
Posted 17 April 2012 - 09:02 PM
Please post a link to your MCB thread, I love seeing rainmakers :D
#5 User is offline   Klub
  • i haz a pickle
Posted 17 April 2012 - 09:15 PM
http://www.mcarterbr...tml#post2308254
Here is the mcb thread
#6 User is offline   Myrkul
Posted 17 April 2012 - 09:17 PM
View PostKlub, on 17 April 2012 - 09:15 PM, said:
Thanks,
Cya There!
#7 User is online   canscom
  • Our PeacKeepers Tell Of there Own Living Hell
Posted 17 April 2012 - 10:19 PM
What the Hell
Quote
#8 User is offline   cocker addict
Posted 17 April 2012 - 10:55 PM
okay so I just quickly looked at my rainmaker.
The wiring harness:
-the button switch is the trigger switch and it's correct
-those 2 black wires do connect to the mac valve
-the on/off switch you can just splice into the either the negative or the positive of the battery pack. Mine is spliced into the positive.
#9 User is offline   Klub
  • i haz a pickle
Posted 17 April 2012 - 11:11 PM
Ok, thank. any idea where the mac valve goes to?
#10 User is offline   cocker addict
Posted 18 April 2012 - 06:57 AM
originally they were just ziptied under the ram, but the frame with the dye stickies has a aftermarket mac mount which your valve will attach to.
#11 User is offline   Klub
  • i haz a pickle
Posted 18 April 2012 - 06:00 PM
Oh ok, so I have most everything, so I may get soldering today hopefully.
I am also using a 4 AA pack since it is the older board.
This post has been edited by Klub: 18 April 2012 - 06:10 PM
#12 User is offline   cocker addict
Posted 18 April 2012 - 06:58 PM
cool, good luck man. If you need anymore help just post it up.
This post has been edited by cocker addict: 18 April 2012 - 06:58 PM
#13 User is offline   Klub
  • i haz a pickle
Posted 18 April 2012 - 07:05 PM
Oh, I will. Still not sure where all the hoses go haha.
#14 User is offline   cocker addict
Posted 28 April 2012 - 07:03 PM
hey klub, just wondering how that rainmaker is coming? You figure out the hoses went or do you need me to open mine up?
#15 User is offline   Klub
  • i haz a pickle
Posted 29 April 2012 - 08:16 PM
Ok, Just found some solder that will work well, and a batterey pack.
And yes please to the hoses, I am a little confused as to where they go.
#16 User is offline   cocker addict
Posted 29 April 2012 - 10:33 PM
C. is where your hose from the LPR goes.
This post has been edited by cocker addict: 29 April 2012 - 10:41 PM
#17 User is offline   Klub
  • i haz a pickle
Posted 30 April 2012 - 12:15 AM
Ok, got the hoses hooked up, but now it is leaking down the bolt.
#18 User is offline   drg
Posted 30 April 2012 - 03:11 AM
Ooh rainmaker.... BLAM! BLAM! BLAM!
How's your main pressure? How's the valve condition?
It's basically a backwards sheridan-style valve in there.
Keep your pump hand strong!
HawaiiPB/PumpPB - Our videos
#19 User is offline   Klub
  • i haz a pickle
Posted 02 May 2012 - 06:09 PM
could it possibly be the cup seal?
I'm not sure what pressure the reg is running at, It is a ccm reg.
#20 User is offline   cocker addict
Posted 02 May 2012 - 07:25 PM
The bolt needs to be forward when you air it up, sometimes they will leak if you air the gun up with the bolt in the rearward position. Just take the bolt cover off and push it forward with your finger. It's more then likely the valve seal is dry. It's located behind the HPR, the reg is held into the body with 2 allen bolts. Rainmakers LOVE lube!!!!!
I'd personally replace the o-rings inside the whole marker, there is a pretty good chance that they are over 8 years old.
Does the gun cycle?
This post has been edited by cocker addict: 02 May 2012 - 07:26 PM
