TechPB Forum: Cheapest stock class pump? - TechPB Forum
#1 User is offline   Paintballingdrummer
Posted 24 April 2012 - 03:13 PM
any ideas?
#2 User is offline   Cj R
Posted 07 June 2012 - 02:35 AM
Probably the best pump gun for the price is the Azodin Kaos Pump. There's no need for aftermarket parts unless you feel the need for it. I recommend getting the Hitman mod for it though.
Kaos Pump: http://www.ansgear.c...mp2011black.htm
Hitman Mod: http://www.ansgear.c...oshitmanmod.htm
Goodl luck :)
#3 User is offline   TK-421
  • Me So Horny! :D
Posted 07 June 2012 - 02:50 AM
Probably the PGP, you can find them for $50-75.
#4 User is offline   Mocking Da Bird
  • Hold it down with the AXE!
Posted 16 June 2012 - 04:10 PM
Goodl luck :)
The Azodin is a open class pump.
Empire Axe, Ninja 68/45, Rotor, Empire jersay, Proto pants, Proto 3+4, Events
#5 User is offline   ShadowZero
  • Karma Police
Posted 16 June 2012 - 09:32 PM
Phantom/Grey Ghost.
Phantom is cheaper.
-My YouTube (More Videos To Come Soon!)
#6 User is offline   Squirt
Posted 16 June 2012 - 10:45 PM
Goodl luck :)
1. the azodin is open class.
2. the hitman mod comes with it
#7 User is offline   pb=life
  • I like penguins
Posted 16 June 2012 - 11:02 PM
pgp, then traccer, then a used phantom
#8 User is offline   IVIidnight
Posted 16 June 2012 - 11:39 PM
i would say just go for a used phantom, you cannot go wrong with a phantom. Literally. If you dont like it theres soooooo many different setups you can do with some parts and if all goes wrong sell it for all your money back.
#9 User is offline   Jawz
  • MOONBASE!
Posted 20 June 2012 - 11:40 AM
Tippmann C3 Cooky just filled me in that it shoots FLAMES!!! how awesome is that! oh and it gets about 50,000 shots off of one propane tank :P
View PostJ4 Paintball, on 24 May 2013 - 01:12 PM, said:
Jawz is our new favorite customer. You can have the first one Sir!
GODDAMNIT OEF!!! STOP CHANGING MY SIG!!!!
#10 User is offline   epic woodsballer
Posted 22 July 2012 - 05:46 PM
The brass eagle raptor all the way! I use it more than my dm12. Lolz
OYP Marauders
#11 User is offline   Squirt
Posted 22 July 2012 - 06:08 PM
necro
#12 User is offline   epic woodsballer
Posted 22 July 2012 - 08:10 PM
What does necro mean?
This post has been edited by epic woodsballer: 22 July 2012 - 08:11 PM
OYP Marauders
#13 User is offline   paintballguy2255
Posted 23 July 2012 - 09:50 PM
Its when you bump a post for no reason other than to annoy people.You didn't necro because you actually said something informative.
#14 User is offline   imawsome!
Posted 25 July 2012 - 11:20 AM
if you get the azodin kaos pump go with the limited edition with a single trigger frame. its 20 dollars more than the regualer pump
My link
This post has been edited by imawsome!: 25 July 2012 - 11:26 AM
#15 User is offline   imawsome!
Posted 25 July 2012 - 11:23 AM
for a stock class i say dont do it you have to rock and cock it its alot harder than regular pump but if you must have a stock class go with phantoms or somthing
#16 User is offline   Jaccen
Posted 25 July 2012 - 01:42 PM
Cheapest? A Talon, likely. Or maybe a Splatmaster.
#17 User is offline   paintballguy2255
Posted 25 July 2012 - 02:19 PM
This,or get the kaos and put a piece of 1" PVC pipe in the feedneck and a 12 gram changer.If you get the kaos and modify it,then you might aswell save up for a phantom.The VSC(vertical stock clas)is $250,which is only about $70 dollars more than the kaos.
http://www.phantomon...uns/primary.htm
This post has been edited by paintballguy2255: 25 July 2012 - 02:20 PM
