TechPB Forum: G3 L7 bolt Engine problem - TechPB Forum
#1 User is offline   CrayonColors1
Posted 14 May 2012 - 05:21 PM
I put in my new L7 engine with and when i shoot it the first shot goes no where or it just gets stuck in the barrel and has i keep shooting the velocity increases . My dwell is at 9. Is it because I have to break it in? or is there some i have to do in my virtue board? somebody please help
#2 User is offline   TK-421
  • Me So Horny! :D
Posted 14 May 2012 - 05:28 PM
Raise your dwell up, you can't lower it immediately, you have to get it broken in before you can lower your dwell. And make sure it's well lubed.
#3 User is offline   CrayonColors1
Posted 14 May 2012 - 05:49 PM
how high should i put it like 12 or 13
#4 User is offline   TK-421
  • Me So Horny! :D
Posted 14 May 2012 - 05:52 PM
I think the stock is 14, try it at that
#5 User is offline   andrewthewookie
Posted 14 May 2012 - 07:02 PM
The lowest possible dwell I could get my G3 to run consistently on with the bolt engine was 10ms, and that was right after I lubed it. I usually bumped it up to 11ms just to be safe.
Fear is the mind-killer
#6 User is offline   CrayonColors1
Posted 14 May 2012 - 07:19 PM
Alright thanks for the help
