TechPB Forum: How to fix code fails - TechPB Forum
#1 User is offline   andrewthewookie
Posted 17 July 2012 - 07:58 PM
Go here: http://www.garyshood.com/htmltobb/
Copy the big block of code, paste it in the box that says "HTML:" then click the "convert HTML" button on the bottom. It should fix the code, giving you a clean format that you can just copy and paste back into your post.
Fear is the mind-killer
#2 User is offline   pb=life
  • I like penguins
Posted 17 July 2012 - 08:03 PM
isn't there also a box or something you can uncheck which fixes coding fails? I think it makes everything show up as html code like :dodgy: shows up as :.dodgy: without the . It was one of the admins that told me that. I'll try to find it.
#3 User is offline   pb=life
  • I like penguins
Posted 17 July 2012 - 08:09 PM
I beleive it was crazylittle who told me to uncheck "Enable visual (RTE) editor?" under general settings.
#4 User is online   dertydood
Posted 31 July 2012 - 09:44 PM
This actually somewhat worked, except it took everything else that was on the page with it. Easy fix though.
