when i air the it up the gun gets a huge leak, it's coming from a hole in the breach that sit's beneath the bolt in the cocked position, (and when you pump it back the hole is uncovered), i couldn't get it to stop leaking, i think it may be a broken oring (hopefully) because i aired it up two days ago and it was perfectly fine
'99 lightning pump leak
#1
Posted 21 July 2012 - 07:16 PM
