TechPB Forum: Macroless Mech Ion - TechPB Forum
  • 3 Pages +
Macroless Mech Ion
#1 User is offline   andrewthewookie
Posted 24 July 2012 - 09:55 PM
So I've got a mech Ion which I absolutely love, and a suggestion in the Hoseless Hustlers got me thinking. Because it's a mech, there's nothing in the grip frame, and I've got a WGP Tickler that I'm not using currently (part of my Impulse build that's on the back burner). That by itself probably wouldn't have sparked my full interest, but then I decided to put my 09 Impulse's ASA on the gun, and lo and behold, it uses standard direct mount ASA screws and placement.
So right now I've got the hole drilled and tapped for the Tickler in the frame, and now I'm just waiting for some end mills to come in so I can clean off the bottom of the Ion ASA and make a counterbore for the o-ring that will seal between the frame and ASA, since the frame on the Ion has a chamfered edge all the way around, and won't seal properly as it is. I'll take the banjo fitting off the front of the frame and attach it to the Tickler, but to do that I'll have to mill out some of the frame, so that's another step that I have to wait on the mail for. I tested the Tickler, and it takes my 850ish input just fine and tops out at 210 psi, so it'll be perfect for the Ion.
Impy ASA
Tickler placement for testing, it's not fully screwed in.
Update 8-15-12
Frame milling is done, and leak test has passed.
Update 8-26-12
New frame milled, and shooting video is done.
Completed gun:
This post has been edited by andrewthewookie: 24 September 2012 - 12:24 PM
Fear is the mind-killer
#2 User is online   kingJurzy
  • TechPB's best member 2012
Posted 24 July 2012 - 10:00 PM
First, and it is looking good.
FEEDBACK: 20/0/0
#3 User is offline   cybermaniac15
  • Elite Member
Posted 24 July 2012 - 10:06 PM
I wanna shoot it!!
#4 User is offline   Cookybiscuit
  • Schadenfreude Fanatic
Posted 24 July 2012 - 10:14 PM
Thats a nice idea, needs more purple though.
#5 User is online   kingJurzy
Posted 24 July 2012 - 10:16 PM
No, it needs more cowbell.
FEEDBACK: 20/0/0
#6 User is offline   WiscoBaller
Posted 24 July 2012 - 10:40 PM
the dragunfly LPRs are smaller, and also hold up better to high pressure tanks. Palmers are for sure, but dragunfly actually did a decent job on the LPRs
The Hooligans Paintball Team
Bob Long Ripper FST
#7 User is offline   andrewthewookie
Posted 25 July 2012 - 04:22 PM
So are you saying the Tickler won't work? Cause I'm not buying a new LPR if I don't have to. Besides, I already tested it on my HP tank, and it worked fine.
This post has been edited by andrewthewookie: 25 July 2012 - 04:25 PM
#8 User is offline   Panda Man
Posted 25 July 2012 - 04:43 PM
but never count out a Palmers Rock Regulator as well, they might be able to fit properly and you could run one of the Valve Hoses through it as well.
Rock Reg
#9 User is offline   andrewthewookie
Posted 25 July 2012 - 04:47 PM
Yeah, I was looking at that, but the Tickler already fits fine, and I can already put a banjo on it so I don't have to worry about barbs. Essentially, I have all the parts, I'm just waiting on tools to finish machining the frame.
#10 User is offline   Panda Man
Posted 25 July 2012 - 04:52 PM
Sweet!!!
I can't wait to see the first "Hoseless Mech Ion" shooting vid!! :D
okay maybe my little gears in my head are moving a little to much, I wonder if you could some how implement a Level 7 bolt system, you need someway to bleed the air, but it would stop any chance of chopping from a Short stroke...
just an idea.
This post has been edited by Panda Man: 25 July 2012 - 04:58 PM
#11 User is offline   Danny D
Posted 25 July 2012 - 10:47 PM
Great Build! Finish her up!
#12 User is offline   Rotozip2
Posted 26 July 2012 - 03:48 PM
Made me start singing this.
#13 User is offline   Hitman2513
  • Save a Rock Throw a Mini
Posted 09 August 2012 - 08:12 PM
I'm bookmarking this :D
Bitches love my Spyder Ion
#14 User is offline   Panda Man
Posted 15 August 2012 - 11:48 PM
hows the build coming?
#15 User is offline   andrewthewookie
Posted 16 August 2012 - 12:03 AM
I actually just finished milling out the frame, I was gonna assemble and test tomorrow, but I'll see if I can get her up and running (mostly) tonight.
#16 User is offline   pb=life
  • I like penguins
Posted 16 August 2012 - 12:43 AM
nice :tup: take a video of it.
#17 User is offline   andrewthewookie
Posted 16 August 2012 - 01:33 AM
OP updated with video of the system aired up and working.
#18 User is offline   cybermaniac15
  • Elite Member
Posted 16 August 2012 - 02:18 AM
I'm so freaking jelly!
#19 User is offline   Hitman2513
Posted 16 August 2012 - 03:58 AM
#20 User is online   tallsmallboy44
  • Space Cowboy
Posted 16 August 2012 - 11:01 AM
Shooting video? This thing is amazing.
Feedback 2/0/0
  • 3 Pages +
