TechPB Forum: Future Marker Purchase - TechPB Forum
#1 User is offline   themoshow
Posted 08 September 2012 - 09:09 PM
Hey guys I currently have a 2011 Proto Rail. I was wondering what my next marker that I should shoot for to purchase. Any suggestions would be greatly appreciated.
#2 User is online   CPS
  • That guy who breaks stuff
Posted 08 September 2012 - 09:10 PM
poppit or spool and budget?
#3 User is offline   picaboo8
Posted 08 September 2012 - 09:18 PM
g6r or a used luxe?
#4 User is offline   Tick
Posted 08 September 2012 - 10:59 PM
Csl...
Assuming your budget is maybe 1.5x the cost of your gun, I gotta say Vice
#5 User is offline   jimbob23929
  • Orange Tiger
Posted 09 September 2012 - 10:24 AM
If you really like the proto rail, I would suggest the proto reflex rail. It's very similar in design and is a solid gun for the price.
Check out my youtube channel!!!
Current Marker Setup:
Proto Reflex Rail, Invert Halo TOO Loader with Exalt Speedfeed, Ninja Grey Ghost 68/4500 tank with Dye C7 Blue Rhino cover
Current Gear Setup: Orange Tiger i4 with Orange Tiger Headband and ContourROAM Camera, C12 Orange Tiger Jersey and Pants, PE 2012 Overload Padded Jersey
1/0/0
#6 User is online   CPS
Posted 09 September 2012 - 10:38 AM
he would be getting close to the same gun for more money... an axe or drone would be better then the reflex
#7 User is offline   jimbob23929
  • Orange Tiger
Posted 09 September 2012 - 10:47 AM
While the axe does have many good points, I prefer the reflex. Now my opinion was going off of the idea that he might not want to change very much with his new gun. If he got a reflex, he wouldn't have to learn how to use an entirely new system. Now, if he does want something different, then yes, I would recommend the axe. The drone, however, I know little about so I cannot comment on it.
1/0/0
#8 User is offline   junits15
Posted 27 September 2012 - 03:53 PM
lol i get this feeling you might have a BIT of a bias towards the reflex rail
As for OP, used dye guns are awesome IMO. It would help to know your budget
This post has been edited by junits15: 27 September 2012 - 03:53 PM
TECHPB FEEDBACK IOG FEEDBACK
#9 User is offline   Wolferam
Posted 27 September 2012 - 06:28 PM
Honestly, if you do like the Rail. I'd suggest looking into a Matrix. Maybe the PM7 or even an old DYE marker.
#10 User is offline   Blade of grass
Posted 27 September 2012 - 08:46 PM
Of course he has a bias, a bias is to have an opinion.
#11 User is offline   junits15
Posted 29 September 2012 - 07:23 PM
pm7's are awesome
I will attest to this
#12 User is offline   jimbob23929
  • Orange Tiger
Posted 29 September 2012 - 07:57 PM
well i was going to reply to this with basically the same response, but i was beaten to it! thank you kind sir!
1/0/0
#13 User is offline   vantageman
Posted 08 October 2012 - 09:30 PM
the dp g3 would be my choice, solid gun, really quick, i (being a newbie w/ rolling triggers) can really get on the trigger, and i can find them in the low 100's
#14 User is offline   paintballguy2255
Posted 09 October 2012 - 12:51 PM
I have used the g3,and it was a pretty rough shooter.I say get a used axe or mini.I have shot both of those and they were fairly smooth.If you have smaller hands,then get the mini and put an on/off ASA and better trigger,then you essentially have a baby axe.
#15 User is offline   AndrewH
  • 3L1Te M3Mb3|2
Posted 13 October 2012 - 09:39 PM
I dont know your budget, but I'd wait a little while after world cup when older models drop in price a bit more. Then I sugget a $350-$500 budget and get an ego 7/8, vice, and possibly a g6r for poppits and for spools a dm9/10, geo, or nt(hit or miss).
#16 User is online   RampageEtek3
Posted 02 November 2012 - 03:47 PM
ego 11 or 10 or 9
geo 3 or 2.1
#17 User is offline   fatalreaction
Posted 04 November 2012 - 07:46 AM
Could always try to find a shocker, Very nice examples out there for ~300, if your looking to spend a little bit more i've absolutely fallen in love with the axe
#18 User is offline   Aulldeath
  • Pain is irrelevent, yet inevitable.
Posted 04 November 2012 - 07:58 AM
You can also get used DM12's for around $600 now, thats a pretty great price for a great gun.
Yes, I work at Wal*Mart, got a problem with that?
#19 User is offline   asthmaticrhino
  • Skyrockets in flight! Beeewwww
Posted 16 November 2012 - 02:50 PM
Well assuming you are going to jump into the 500ish price pool, similar options would be the reflex rail, or a used dm, I've seen Dm10s for 500 on trade my gun.For a change from the current setup, look at a vice, you can find them around 400, or maybe an old victory or marq. new look for ethas, eteks, axes, and drones.
bigx, on 20 May 2013 - 09:45 PM, said:
