TechPB Forum: washing stuff again!? - TechPB Forum
#1 User is offline   Silyputy
  • Senior
Posted 07 October 2012 - 07:54 PM
ok went pbing to day had a blast. but my pod pack is covered in paint is it ok to put in the washing machine? and also my pants i know they are but is it ok to wash the t-shirt i wore today also ok to wash in the same load? thanks!
EDIT: should i add soap or no? and if so how much compare to normal?
This post has been edited by Silyputy: 07 October 2012 - 08:47 PM
  • TechPB's best member 2012
Posted 07 October 2012 - 07:58 PM
Take a shower with all your gear on, then throw it in the washing machine.
DO NOT DRY ANYTHING IN THE DRYER.
FEEDBACK: 20/0/0
#3 User is offline   tallsmallboy44
  • Space Cowboy
Posted 07 October 2012 - 08:10 PM
Cold, and on the most delicate settings.
DO NOT USE THE DRYER! HANG DRY!
5ozofpain, on 18 September 2012 - 05:59 PM, said:
Feedback 2/0/0
#4 User is offline   Silyputy
  • Senior
Posted 07 October 2012 - 08:46 PM
ok so ill run it in cold on delicate thanks but what about soap or no soap?
Posted 07 October 2012 - 08:49 PM
yes soap
FEEDBACK: 20/0/0
#6 User is offline   SAHeatpb
  • Yeah let's go with this
Posted 07 October 2012 - 08:58 PM
Just put in washer set on cold and delicate wash then air dry all of it.
#7 User is offline   Silyputy
  • Senior
Posted 07 October 2012 - 10:03 PM
ok thank you very much guys was helpful!
#8 User is offline   SoCalPB22
  • Just Addictied...
Posted 07 October 2012 - 10:04 PM
Pick out the shell if there is any on it
#9 User is offline   PapaThor
Posted 08 October 2012 - 10:59 AM
If you use Oxy-clean along with your regular laundry soap, everything will be clean. Oxy-clean is the best at getting paint out. Just make sure you attach all of your velcro straps before you wash your pack.
Will play for beer!
#10 User is offline   Silyputy
  • Senior
Posted 08 October 2012 - 11:53 AM
ok cool guys used everyones advice worked great all clean thanks a lot guys!
#11 User is offline   Ironchefxingba
  • Local Gun Whore
Posted 10 October 2012 - 09:01 PM
the power of oxy!!! and yes make sure of all the velcro is attatched,
Empire Events, 65/4500 Ninja pro reg. Black/slime Luxe 1.5 w/ 2.0 board, Virtue Spire, critical stealth pack.
