TechPB Forum: Invert mini is it worth it? - TechPB Forum
Invert mini is it worth it? Should I get a invert mini?
#1 User is offline   Yellowsnowpaintball
Posted 08 October 2012 - 05:29 PM
I am a fairly new player and I have played a few times with rental gear and fell in love with the sport. So a invert mini is it worth it
#2 User is offline   SynystrAssassin
  • Flawless is a Habit
Posted 08 October 2012 - 05:35 PM
Nope. I REALLY hated my Mini. There are much better out there for less.
View Posttallsmallboy44, on 17 April 2013 - 11:50 PM, said:
View PostPanda Man, on 17 April 2013 - 11:35 PM, said:
View Posttallsmallboy44, on 17 April 2013 - 11:29 PM, said:
Worst rant ever...
Thats what your sister said when unzipped my pants.
That doesn't even make sense.
#3 User is offline   SoCalPB22
  • Just Addictied...
Posted 08 October 2012 - 05:37 PM
No, if you like the design I a mini step up to an axe. I think that the valken proton might be a better choice it is in the price range of the mini but there is always a choice to go used. You will find some good deals that will blow away the mini
Welcome to The sport And TechPB
This post has been edited by SoCalPB22: 08 October 2012 - 05:38 PM
#4 User is online   kingJurzy
  • TechPB's best member 2012
Posted 08 October 2012 - 06:11 PM
Meh
FEEDBACK: 20/0/0
#5 User is offline   get.lit.up!
Posted 08 October 2012 - 06:55 PM
If you like the feel of it get it used. I'm surprised that some other techpb players club members have not started a buying service yet
#6 User is offline   RLV199
Posted 08 October 2012 - 07:05 PM
I own a mini, I say nah just because you can get other things just as good for cheaper but the ergos arent bad like everyone says
#7 User is offline   Minty Hippo potumus
  • Dont mess with Texas!
Posted 08 October 2012 - 10:11 PM
i'd say its worth it. i got a buddy who is likes his and hasnt had many problems. other than the mini i would say proto rail
American by birth, Southener by the grace of God.
#8 User is offline   NPpballer
  • I'm Rick James, BITCH!
Posted 08 October 2012 - 10:16 PM
Have you ever considered buying used?
You could buy a brand new Mini for what, $320?
I'd recommend picking up an Ego7. Their not the smoothest or quietest, but their light, reliable, and efficient. Newer players shouldn't have to worry about taking care of their gear, Egos are perfect for that.
#9 User is offline   paintballman69
Posted 09 October 2012 - 06:07 PM
NOOOOOOOOOOOOOOO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! the proton is pretty nice and its the same price
Your a towel!!!Posted Image
Youtube.com/paintballman79
#10 User is online   Klub
  • i haz a pickle
Posted 09 October 2012 - 09:05 PM
Before going out and buying a gun, I suggest getting some important gear fist. A good mask, hopper and tank are very important things to have.
#11 User is offline   Tick
Posted 09 October 2012 - 09:07 PM
To the OP:
Ask yourself NEW or USED?
New
- Mini If you're a small(er) player
- Rail
- Excty
Used:
- Axe if you're a small(er) player
- Ego 6/7/8
- VICE
#12 User is offline   Hitman2513
  • Save a Rock Throw a Mini
Posted 12 October 2012 - 01:45 AM
EXTCy and if you take care of it there wont be any problems
Bitches love my Spyder Ion
#13 User is offline   SamBo
  • Group: Players Club
Posted 12 October 2012 - 02:51 AM
Mini is fine if your can get one for 150 or less. My teammate sold his at the field for 100 bucks. If you do get one I suggest the grip extender, on off asa, redline board, as you can see many upgrades.
for 300 you could buy an Alias, Dm7, Fep Quest, Marq 6, or Vice. All of these are high ends that would blow the mini out of the water. Idk if you want spoolie or poppet. GoG is coming out with a 150 dollar spoolie at World Cup (late october) apparently. If that's your price range you might want to try it.
#14 User is offline   TooTallNiCo
Posted 12 October 2012 - 05:20 AM
Be aware though that GoG's new marker is basically a Mech ion (comes with a single trigger frame.)
I always buy used because it saves tons of money. Bought a Darq Marq for $250 locally, and gotten lucky on some other ones as well
LLV Veteran
#15 User is offline   G4paintballer
  • Gun/gear whore
Posted 12 October 2012 - 08:02 AM
I like the mini more than any of the guns under the $300 new price range, and I prefer it's ergos over the axe's.
And guys, he's a new player, do you really think he'll know how to lube an LPR? Ram? Fuse Bolt? Be realistic, the guns gotta be simple.
Feedback 10/0/0
#16 User is offline   epic woodsballer
Posted 12 October 2012 - 11:22 AM
Wait...
This post has been edited by epic woodsballer: 12 October 2012 - 11:33 AM
OYP Marauders
#17 User is offline   epic woodsballer
Posted 12 October 2012 - 11:31 AM
Tippmann 98 is great. It needs basically no maintnence unless something breaks. And it will only break if you do something INCREDIBLY stupid. They don't fire terrible and over all not that bad.
But since you guys are totally going to say hell to the no on this I will give another suggestion. The proto rail is great. It's light, SMOOTH as butter, and feels great. It's a good airball, speedball type marker but will do great in the woods as well. It is also quite. So in woodsball you don't give away position. On the down side it doesn't have many modes, not good feed neck or asa, and doesn't have a great rate of fire but in return its ultra smooth. The efficiency isn't very good on it either. It's also $250.
On the other hand there is the extcy. The board has many modes on the board and its fast. It also has a longer barrel so you can aim better. It has an on off asa, and good clamping feed neck. It's an amazing woodsball marker. On the downside it's heavy, the air line comes through the side of the asa so your hand can rub against it, it has a DVD maual so if anything happens at the field you can't fix it, and some complain it doesn't feel right in there hands but that's just opinion. This one is also $250.
Then there is the mini. Warning I don't know a lot about this one so I may get something wrong or leave something out. A lot of people at my field have these and love them so that tells me something. It has a great feed neck, trigger, its quite, smooth and has a good rate of fire. . It has a bad asa and the biggest problem people have is how small it is. If your hands feel good in the mini then you will like it. That is basically the only problem with it. It's $325.
I personally don't buy used but you can get some good deals on good stuff for cheap by looking through the B/S/T section. Or you can save a little more and buy a mid end like an axe, reflex rail, and etha.
Make sure before you get a gun buy a NICE mask. I can't stress that enough. You will breath better, see better, and hear better. It will be on your face the whole day so make sure it's comfortable. Masks are completely personal preference and you need to try them on first. Here are the ones I suggest. Empire eflex-$100 Sly profits-$90-100 Empire events-$90 And my favorite the dye i4s-$110-120.
Masks are preference try them on before you buy them.
Next is tank anything but co2 will work. You can get a cheap hpa tank for $40-$60. At all costs avoid co2. Enough said.
Then a hopper, something that will keep up with your gun. An invert halo too is great for $75. Then you can get one of my favorites the pinokio for $130. It's light and has a HUGE capacity. If you want the best though go with a dye rotor. They go for like $160-$200 depending on color.
Then if you want get pods and a pod pack so you don't run out of ammo. Finally you get stuff like paintball pants, jerseys, elbow pads, knee pads, and chest protectors. This is optional and you don't need them right off the bat, or ever for that matter but its there if you want it.
So to recap you should buy your gear in this order: mask, tank, hopper, and then gun. I hope you can now make a clear decision and welcome to our wonderful sport! If you ever need any help we will be here.
This post has been edited by epic woodsballer: 12 October 2012 - 11:36 AM
OYP Marauders
#18 User is offline   SamBo
Posted 12 October 2012 - 12:00 PM
That is easy. Manual. Just because hes new doesn't mean hasn't greesed bearings before. or lubed an oring. I could train a monkey to do it that;s no big deal.
#19 User is offline   G4paintballer
  • Gun/gear whore
Posted 12 October 2012 - 04:23 PM
True, but how many new players are confident taking apart a four piece bolt and not shredding an o-ring putting in back in the gun?
Feedback 10/0/0
#20 User is offline   mtn.dew_me
Posted 12 October 2012 - 07:39 PM
Not worth it. Save your cash a little bit more and get a etha
