TechPB Forum: deciding on first pump - TechPB Forum
deciding on first pump pump my cocker, phantom or azodin kaos pump
#1 User is offline   Pump Player
  • Voted techpb's #1 sloth
Posted 15 October 2012 - 07:25 PM
i can either get a pump kit for my lightning, a CCI phantom or an azodin kaos pump
View PostUKPaintball said:
We’re now providing additional padding around the chest region to any surgically enhanced female participants.
#2 User is offline   Sydarm
  • XTC + Ninja + Pinokio
Posted 15 October 2012 - 07:28 PM
Phantom for stock class, else I would prefer a regulated cocker w/ pump kit myself.
#3 User is offline   get.lit.up!
Posted 15 October 2012 - 07:30 PM
Depends what you want in a pump. I own 2 phantoms, and have shot a ccm'd superstock. I can tell you I like the smoother pump action so that's why all my phantoms are going to the chopping block.
#4 User is offline   LUXOR54
  • TechPB's smart ass
Posted 15 October 2012 - 10:47 PM
my sniper is so sexy Posted Image
if i were you i would put a kit on your lightning
New found pumper,
Set-up: Black/gold E2 Karnivor, Dye rotor, Guerrilla air 68/4500, CP 14" .685, Black/Gold Dye I4's, Dye core pads, Venomwear, Etek3 LT. Orange 2k5 superstock, CCM'd
Proud Canadian citizen
#5 User is offline   o-baller
Posted 15 October 2012 - 11:10 PM
Pump kit on lightning. If you don't like pump you haven't lost much and you can convert your gun back to semi at any time. Unless of course you want stock class, which then basically means a phantom or a used grey ghost (my choice).
Sqaush the Bug and Whip the Hips- Coach Watkins
98% of statistics in peoples sigs are made up
