TechPB Forum: My SFT Budget Build - TechPB Forum
My SFT Budget Build Shocker Newb!
#1 User is offline   WiscoBaller
Posted 20 October 2012 - 08:44 PM
My build so far:
Price so far: $118
Parts so far:
Blue SFT Body
Stock Bolt engine missing bolt guide
Nerve board
VA with gauge
Complete bolt engine+guide with HE bolt, Non HE can
Trigger frame
Freak barrel with no inserts
Redz two piece Pepper stick 16" .689 bore
Filters
SFT trigger
Empire Chrome reg
Broken Parker Noid
Parker Noid Board
To be purchased:
Oring set
Screw Set
Ramping/12.5 compatable board
Asa
Rail
Manifold
Feedneck ring
To be done:
Have noid/board fixed
Choose an anno (:
Pics:
This post has been edited by WiscoBaller: 28 November 2012 - 10:45 AM
The Hooligans Paintball Team
Bob Long Ripper FST
#2 User is offline   junits15
Posted 31 October 2012 - 07:10 PM
oo can't wait to see how this comes out! Are you going for a shocker that compares to a luxe?
TECHPB FEEDBACK IOG FEEDBACK
#3 User is offline   WiscoBaller
Posted 01 November 2012 - 07:13 PM
considering tomorrow I will be a new luxe owner, I would like it to shoot similar to my luxe (:
Bob Long Ripper FST
#4 User is offline   nighthunter
Posted 01 November 2012 - 11:04 PM
It appears you have a non-HE bolt, but an HE bolt guide; unless you got two bolt kits.
If you can't find a replacement ring for the feedneck, it's Ion threaded and replacements can be had just about anywhere.
It looks like you've got a decent start on the build.
That body looks somewhat sexy as is.
View PostAntonious, on 23 December 2011 - 04:37 PM, said:
My Gearbag Sale!
#5 User is offline   WiscoBaller
Posted 03 November 2012 - 11:02 AM
it's really good that you say that about the bolt guide, because I picked up another bolt engine with an HE bolt and non HE guide (:
I'll take pics of where I am at in a bit (:
Bob Long Ripper FST
#6 User is offline   WiscoBaller
Posted 03 November 2012 - 11:08 AM
Bolt engine parts: Posted Image
Bob Long Ripper FST
#7 User is offline   LV Backpacker
Posted 03 November 2012 - 11:22 AM
Both of your bolt guides are HE. Not 100% sure, but it looks like you have one HE can and one sft can. You can tell HE bolt guides by the fact that they have a smaller radius between the two orings. As for cans, the HE can's front piece pops off, while the sft can is just 1 piece.
This is the standard non HE guide:
Gearbag
#8 User is offline   WiscoBaller
Posted 03 November 2012 - 02:10 PM
I believe both of my bolt guides are SFT guides, as neither of them come apart.
This post has been edited by WiscoBaller: 03 November 2012 - 02:12 PM
Bob Long Ripper FST
#9 User is offline   LV Backpacker
Posted 03 November 2012 - 02:50 PM
I think you mean cans. The guides aren't supposed to come apart.
HE can:
Gearbag
#10 User is offline   WiscoBaller
Posted 03 November 2012 - 03:02 PM
I tried pulling them both apart, and neither would. They both only have one hole between the orings. I am guessing I have two sft guides?
Bob Long Ripper FST
#11 User is offline   LV Backpacker
Posted 03 November 2012 - 04:07 PM
They're not guides. They're called cans, but yes, if they were HE cans, they'd easily pop open.
Gearbag
#12 User is offline   andrewthewookie
Posted 03 November 2012 - 07:17 PM
If you look in the front, you should be able to tell quite easily. If it's an SFT can, there's no inner lip right after the air transfer holes, if it's an HE can, then it's got that lip after the holes that seals against the HE o-ring on the HE bolt.
This post has been edited by andrewthewookie: 03 November 2012 - 07:29 PM
Fear is the mind-killer
#13 User is offline   WiscoBaller
Posted 04 November 2012 - 03:05 PM
yeah, then I have two SFT cans.
Bob Long Ripper FST
#14 User is offline   MUNK3H
Posted 05 November 2012 - 01:44 PM
www.armorypaintball.com try there i found him to have some shocker parts for fair prices.
This post has been edited by MUNK3H: 05 November 2012 - 01:45 PM
#15 User is offline   XxJellyFilledxX
  • dat fity snake
  • Group: Chat Moderator
Posted 11 December 2012 - 07:36 AM
well thread jack kinda... Me and the OP ended up trading some stuff.
So all it needs as of right now is:
Top board soldered to noid,
Eye cover
wire that goes between the upper/lower board
board pin
gauge for reg,
Grips
straight macro fitting.
and a cool looking bolt guide.
How do you guys think an all polished scheme would look on this bad boy?
This post has been edited by XxJellyFilledxX: 11 December 2012 - 07:40 AM
What R this?
#16 User is offline   WiscoBaller
Posted 11 December 2012 - 11:30 AM
I loved that body the way it looks ):
Looks good together tho (:
Bob Long Ripper FST
#17 User is offline   tallsmallboy44
  • Space Cowboy
Posted 11 December 2012 - 03:20 PM
Y u no finish Wisco?
Feedback 2/0/0
#18 User is offline   WiscoBaller
Posted 11 December 2012 - 06:21 PM
I'm a back player and I need poppits, also ran out of money to put into the project. Had a luxe and a vapor, so I know what it would shoot like.
Bob Long Ripper FST
#19 User is offline   LV Backpacker
Posted 13 December 2012 - 01:52 PM
Lurker bolt, problem solved.
Gearbag
#20 User is offline   WiscoBaller
Posted 13 December 2012 - 02:02 PM
ego 10, problem solved
Bob Long Ripper FST
