TechPB Forum: Great Budget Baller Idea/Tutorial - TechPB Forum
#1 User is offline   Woodyballer29
  • Brass Eagle Fanboy
Posted 25 October 2012 - 09:30 PM
Yes I do stutter lol.
http://www.youtube.c...d&v=41PCZZ5Exsc
This post has been edited by Woodyballer29: 25 October 2012 - 09:39 PM
#2 User is offline   Corysllw
Posted 25 October 2012 - 09:40 PM
Wow that's a pretty cool idea! Nice video!
#3 User is offline   Woodyballer29
Posted 25 October 2012 - 09:42 PM
Haha thanks man I appreciate it! As you can tell I was a bit nervous...
#4 User is offline   Corysllw
Posted 25 October 2012 - 09:54 PM
Ha you did good! I really do like this idea though.
#5 User is offline   Woodyballer29
Posted 26 October 2012 - 07:21 AM
Thanks!
#6 User is offline   Old Dude PB
  • Old enough to know better, theoretically.
Posted 26 October 2012 - 10:12 AM
Walking into a paintball field with a suitcase is badass. You should paint biohazard and radiation warning signs on it. Nice vid. Make more.
My index of TechPB YouTube reviews: A-F, G-Z
Pumpbusters' summary of marker efficiency testing
#7 User is offline   Aulldeath
  • Pain is irrelevent, yet inevitable.
Posted 26 October 2012 - 10:30 AM
If you take a briefcase, they are the right size for a gun + extras. Just customize it up and it makes it even more badass then a suitcase.
Then you can wear a suit. Or a suite-shirt with no sleeves.
Yes, I work at Wal*Mart, got a problem with that?
#8 User is offline   Woodyballer29
Posted 26 October 2012 - 12:45 PM
Ahaha thanks bro! I was thinking of painting it camo but that's even cooler. Btw the tape says, DSP's PB Gear, This side up!!
Yeah it's kind of nice how I can fit almost all of my stuff in there, and it's really light. I plan on doing some customizing just working on some ideas right now, and I might be getting a new gun, barrel, tank(s), and hopper so I will have to change the foam on it. Then I will start making it look sick!
#9 User is offline   Aulldeath
Posted 26 October 2012 - 01:27 PM
I used my mom's old briefcase to put my TM7 in. Put camo duct-tape over the outside, had a combination lock on it as well.
With real foam from the TM7 box put into it, it fit perfectly.
#10 User is offline   Woodyballer29
Posted 26 October 2012 - 01:31 PM
Oh and I would make more videos but I don't have an sd card for my camera so I only have like a minute and a half of time. Hopefully I'll be getting one soon so I can post more videos.
#11 User is offline   Woodyballer29
Posted 26 October 2012 - 02:36 PM
Nice! A combo lock is a good idea, on mine the closing pieces have a key hole, but there is no key in the suitcase, so I can't lock it :( I could easily get a key made though, but where I play, we all know each other so it's not like we would steal stuff. But for a scenario game, it would definitely be useful. And I plan to make a full tutorial with pictures on how to do it.
This post has been edited by Woodyballer29: 26 October 2012 - 02:38 PM
#12 User is offline   Aulldeath
Posted 26 October 2012 - 02:49 PM
Her briefcase had a 6 number combo built in, worked great.
#13 User is offline   Woodyballer29
Posted 26 October 2012 - 02:50 PM
Yeah I bet!
#14 User is offline   Aulldeath
Posted 26 October 2012 - 02:54 PM
Unfortunately, I traded it with the TM7, and the guy just trashed it.
I mean, I spent some good time making that thing perfect, and he just tosses it, kinda makes ya sad :( .
#15 User is offline   Woodyballer29
Posted 26 October 2012 - 03:04 PM
Yeah for sure, in fact it's better than most gun cases that come with the gun, (ex. Dye's, Machine's, PE's Etc.)
#16 User is offline   Woodyballer29
Posted 27 October 2012 - 09:56 PM
BUMP!
