Whats wrong with my Ion?
#1
Posted 03 November 2012 - 07:08 PM
ok so when you pull the trigger it won't shoot but the light blinks but when you keep hitting it after about 15 hits in a row it starts firing and when you stop firing the same thing happen its not the battery tried new ones and different brands and i lubed everything what is wrong with it anything will be appreciated
Thanks
Thanks
#2
Posted 03 November 2012 - 07:15 PM
Does it have a stock board?
Yes, I work at Wal*Mart, got a problem with that?
#3
Posted 03 November 2012 - 07:31 PM
have you dissassembled the noid? Sometimes the noids gum up and it takes a few shots to get them to cycle properly. It could also be the coil on the noid going bad. I would attempt to set the trigger adjustment for the board switch further back, see if that changes it, and if not, the noid would be my next guess.
The Hooligans Paintball Team
Bob Long Ripper FST
Bob Long Ripper FST
#5
Posted 03 November 2012 - 10:22 PM
Check the above issues, and also be absolutely certain that you have a brand new & premium 9v battery installed.
edit: Is it only a stock Ion board? Perhaps FSDO issue?
This post has been edited by Sydarm: 03 November 2012 - 10:22 PM
#6
Posted 04 November 2012 - 12:07 AM
no it has a cp 14 inch barrel
i could try that and before it starts firing theres like an air gap like a shot starts and fails
#7
Posted 04 November 2012 - 12:09 AM
