TechPB Forum: What is wrong with my ion - TechPB Forum
#1 User is offline   member
Posted 04 November 2012 - 08:43 PM
so my ion xe is having some problems its hard to exsplain so heres a video and its not the battery tried several diffrent kinds and new ones
http://s1284.beta.ph...html?sort=3&o=0
and the only reason that i have a gravity feed on there is cause my halo broke and my new rotor is in the mail
#2 User is offline   DBeck
  • Dem Milkshakes
Posted 04 November 2012 - 08:56 PM
im thinking bolt stick
#3 User is offline   member
Posted 04 November 2012 - 09:12 PM
i relubed it
already
#4 User is offline   Sydarm
  • XTC + Ninja + Pinokio
Posted 04 November 2012 - 09:51 PM
Do you have a blackheart board or the stock ion one? The stock Smart Parts boards are notorious for their lack of ABS (anti-bolt stick). On a spool, you essentially need an extra long dwell to be used when the marker has not been fired recently. If you don't have ABS, your kind of issue can happen.
If you have a blackheart board, up the ABS setting...or even the dwell a little as well.
If bolt stick is indeed your issue, and not a result of a lubrication/oring fault, then I don't think there is much you can do if your board is junk.
This post has been edited by Sydarm: 04 November 2012 - 09:52 PM
#5 User is offline   member
Posted 04 November 2012 - 10:11 PM
so should i get a blackheart or virtue board or sell it and get a new marker?
#6 User is offline   member
Posted 05 November 2012 - 09:55 AM
if i got an anti stick bolt would the problem stop
#7 User is offline   AT3256
Posted 05 November 2012 - 11:27 AM
Try upping your dwell a bit.
#8 User is offline   matt12098
Posted 24 November 2012 - 05:51 PM
everything sell ur ion and thank me later
#9 User is online   tallsmallboy44
  • Space Cowboy
Posted 24 November 2012 - 06:49 PM
No. He should attempt every possible solution without spending money, if no solution arises, then he should try the next least expensive option.
5ozofpain, on 18 September 2012 - 05:59 PM, said:
Feedback 2/0/0
#10 User is offline   Mexico
  • police the fuck
Posted 24 November 2012 - 07:45 PM
This. Ions are awesome and make great shooters.
#11 User is offline   junits15
Posted 25 November 2012 - 08:59 AM
WELL....
there are better guns for the money
TECHPB FEEDBACK IOG FEEDBACK
