TechPB Forum: Ion regulator - TechPB Forum
Ion regulator
#1 User is offline   dorian98
Posted 04 November 2012 - 10:12 PM
I can't really afford a cp regulator so I wanted to know if this would be fine
http://www.ansgear.c...egulatorred.htm
#2 User is offline   Jarz
Posted 04 November 2012 - 10:14 PM
I've heard good things about the Azodin regulators.
http://www.ansgear.c...gory_s/2532.htm
#3 User is offline   andrewthewookie
Yes, that should be fine.
They're also nearly twice as expensive
Fear is the mind-killer
#4 User is offline   Pakistani
  • www.AliZaman.com
Posted 04 November 2012 - 10:32 PM
that regulator IS a cp regulator.
shocktech regulators are remilled CP regs.
KPS Paintball • VCU Rams • Richmond Rage•••••••If you need help with a Dye gun, PM me!
#5 User is offline   dorian98
Posted 05 November 2012 - 06:19 AM
K thanks for your input I just bought it
#6 User is offline   Orange Chicken
Posted 05 November 2012 - 09:17 PM
That one looks fine, just wondering, is the only way to change the velocity on the ion is through the reg?
#7 User is offline   andrewthewookie
Posted 05 November 2012 - 09:30 PM
Yes.
