TechPB Forum: Empire sniper problem - TechPB Forum
#1 User is offline   PBtexas
Posted 05 November 2012 - 10:47 PM
Airs up fine, no leaks. The gun wont shoot over
230 fps. I look at the gauge and its passed 300 it looks
As if it would be at 500 psi.... am i supposed to be
Using a low pressure tank?? i set the psi to 200 i shoot
A couple times then it dropped to 100 psi by itself.
Any ideas?
This post has been edited by PBtexas: 05 November 2012 - 10:48 PM
#2 User is offline   Demon
  • Master Tech
Posted 06 November 2012 - 12:22 AM
make sure the HPR is screwed completely together and the IVG is set at about all the way out and use the .675 bore, then set the HPR to 225 psi and see where it shoots, if it keeps changing take the set screw out put some blue loc-tite on it and set it to 220 psi or whatever it is stock i can't remember off the top of my head.
#3 User is offline   Rotozip2
Posted 06 November 2012 - 12:41 AM
Put it on a real pressure tester, the gauges that empire uses are less than below quality.
#4 User is offline   Karnokr
Posted 06 November 2012 - 01:30 AM
Just curious, did you read the instructions on setting your velocity? You don't set it with the reg like an electro. Set the HPR to 225 and use the IVG to get the velocity you want. Just asking because you don't mention anything about adjusting the IVG in the OP. If the HPR pressure is not staying consistent, use Demons advice.
Hand of Fate Scenario Paintball Team http://www.facebook....s/HOFpaintball/
#5 User is offline   NJC
  • pumper
Posted 17 November 2012 - 01:39 AM
use the IVG
View Post-ORaNGe-, on 18 November 2011 - 04:24 PM, said:
*Waits to get hit*
#6 User is offline   Pump Player
  • Voted techpb's #1 sloth
Posted 20 November 2012 - 12:47 AM
sweet spot, theres a certain point where increasing reg pressure will lower you velocity, they recommend 225 psi, try that and adjust the IVG (clockwise+ counterclockwise-)
View PostPanda, on 31 March 2013 - 04:51 PM, said:
I'm gonna have to say throwing brittle paintballs.
Nothing's more reliable than your fapping arm.
#7 User is offline   David A.
Posted 20 November 2012 - 09:10 AM
Pump Player has it right^^^^
Autocockers have to run at the right pressure and sweet-spotting your regulator is an important step in tuning your Sniper into the face-painter you are looking for. Sweet-spotting will take only about 15-30 minutes. When you are done, your Sniper will shoot quieter, more efficently and consistently.
To start you will need a place to shoot, some paint, Allen keys, a Chronograph and some air. If you field has a Chrono station/ range, it is a great place to do this tuning.
Start by turning your IVG (Internal Velocity Govenor or the velocity adjuster on the back of the frame) open up until it is loose, then give it one turn in.
Next turn your regulator all the way closed, not tight, just until it touches, then open it up 1turn.
Gas your gun, shoot three shots over the Chronograph. Now adjusting the regulator 1/2 turn at a time continue this process, your velocity will go up and up and up....then down. When it starts going down, fine tune your regulator until you reach maximum velocity. At that point your regulator is sweet-spotted.
Now your velocity should be high, too high - now use your IVG to adjust your velocity down to your field limit. When you change paint, conditions change or use a different barrel back, only use the IVG to adjust your FPS.
After you shoot a few cases and get your regulator broken-in, re-check your sweet-spot. At this point, you should not need to mess with it for a long time.
Good Luck!
This post has been edited by David A.: 20 November 2012 - 09:11 AM
My Rigs: Dust Black Empire AXE, Nano Feed-neck, Red Critical Axiom Trigger, BOSS V2 Bolt, 14"Deadlywind Fibur Barrel, Dye Rotor Hopper, Critical 45/4500 & 68/4500 Carbon Fiber Tanks with Ninja Regulators. Dust Black CCM T2, 10” Deadlywind Fibur Barrel, Sport Shot 100 Round Hopper, Ninja 13/3000 Tank. Dust Back Sanchez Machine SM-1, CP Shorty Gen 3 Regulator, CP Drop and On/Off, Empire Star Wars Grips, 12” Deadlywind Fibur Barrel, Sport Shot 100 Round Hopper, Ninja 13/3000 Tank.[/size]
#8 User is offline   Demon
  • Master Tech
Posted 20 November 2012 - 01:41 PM
the empire snipers generally sweet spot at 225 to 230 psi just set it to factory and use it, no need to go into sweet spotting if he can't understand just getting it to shoot 280 in the first place.
#9 User is offline   bassfisher
Posted 20 November 2012 - 07:45 PM
My sniper is set at about 225 psi on the gauge, my ivg is cranked in about 3 or 4 turns. It right at 285.
Carolina Riot Scenario Team
#10 User is offline   David A.
Posted 20 November 2012 - 08:47 PM
Good point
#11 User is offline   bassfisher
Posted 20 November 2012 - 09:37 PM
Also, the auto trigger does need some timing, but it isn't 100% necessary
