TechPB Forum: Dangerous power G4 or the Valken proton - TechPB Forum
#1 User is offline   Decoy_Pony
Posted 16 November 2012 - 08:36 PM
Im looking into a cheap-ish intermediate paintball gun and I have narrowed it down to these two: the G4 and the Proton. Now i need some feedback.
  • TechPB's best member 2012
Posted 16 November 2012 - 08:39 PM
Both are horrible for their price.
FEEDBACK: 20/0/0
#3 User is offline   Decoy_Pony
Posted 16 November 2012 - 08:45 PM
Ok, well what would you recommend?
#4 User is online   A&MBaller
  • Sloths are the best animals evar
Posted 16 November 2012 - 08:47 PM
Proto Rail, or GoG extcy. Phenomenal for the price!
#5 User is offline   Decoy_Pony
Posted 16 November 2012 - 08:56 PM
True, and I have considered both but i don't care for how the extcy looks.
#6 User is offline   kingJurzy
Posted 16 November 2012 - 08:59 PM
Why does it have to be about looks?
I would play with a piece of poo if it got 20 pods off of a 50/4500 and was the quietest and most consistent marker out there.
FEEDBACK: 20/0/0
#7 User is offline   Decoy_Pony
Posted 16 November 2012 - 09:02 PM
As would anyone, but I want a gun that appeals to me visually.
#8 User is offline   Sydarm
  • XTC + Ninja + Pinokio
Posted 16 November 2012 - 09:57 PM
Then get the Reflex. The Proton is just a Mokal Aura :tdn:. The G4 is a risk of hit or miss.
#9 User is offline   Decoy_Pony
Posted 16 November 2012 - 10:31 PM
I shall consider it.
#10 User is offline   Hitman2513
  • Save a Rock Throw a Mini
Posted 17 November 2012 - 01:32 AM
GoG eXTCy
Bitches love my Spyder Ion
#11 User is offline   crPaliza
Posted 17 November 2012 - 02:51 AM
Best budget marker currently available under $350 is the GoG eXTCy or the Proto Rail. Check out my Comparison Review and maybe you'll like either or more.
Otherwise,
If you are already looking into $500 range you should also take a look at the Etha, Etek 4, and Axe. Or if you want a spool then yes the Reflex seems like a good choice.
#12 User is offline   crPaliza
Posted 17 November 2012 - 02:54 AM
Also, as per REDCOBRA refurbished Proto Rail's are going for $180 on eBay.
#13 User is offline   stuff21397
Posted 26 November 2012 - 07:20 PM
G4 by a mile. I have one it works fine i have no bolt stick or any other problems, im also the third owner. The bolt stick only happens because the board comes stock with ABS off and DP uses a thick lube. If you set the ABS to 3 then you'll have no first shot drop off or bolt stick(the stock setting is 4, 1 = 1 millisecond extra, 2 = 2 millisecond extra, and 3 = 3 millisecond extra) , also ClEAN the gun regularly and you won't have any problems those who do usually say, "Well i haven't lubed it or opened it up for 3 months idk why its not working." If you service it it WILL work. The G4 also comes with a phenomenal asa the raps is very easy to use and works much faster and better than a screwin on/off. A proton comes with a claper-noid like that in a SPIDER. The proton also is set up differently. It has a macroline-less design so the reg is in the grip frame and the board is in the foregrip thing (not sure what to call it since its not a reg) like a mini. I've never had a mini so i don't know if its more difficult to service a reg thats in the grip frame but I would assume so.
#14 User is offline   BlackoutChristian
Posted 27 November 2012 - 12:26 PM
The G4 is ok but the trigger is stiff and the proton is like the Minsk aura
I mean mokal aura
#15 User is offline   Marnier15
Posted 27 November 2012 - 03:57 PM
You might as well get the dp g5
#16 User is offline   Hitman2513
Posted 28 November 2012 - 01:36 AM
First to say It's not even out -_-
#17 User is offline   tatersinmytummy
Posted 28 November 2012 - 11:24 PM
most shops have them shipping today.
#18 User is offline   recklessbob
  • Welts Don't Wipe
Posted 28 November 2012 - 11:57 PM
personally i would buy used. you can get much more performance for your money
68/4500-
#19 User is offline   Pump Player
  • Voted techpb's #1 sloth
Posted 30 November 2012 - 06:48 PM
used bob long vice, AMAZING!
View PostUKPaintball said:
We’re now providing additional padding around the chest region to any surgically enhanced female participants.
#20 User is offline   chunkums88
Posted 02 December 2012 - 09:37 PM
I have used a g4 for the past 2 years and have had nothing but problems. Bolt stick, bad solenoid, frequently broken orings. I would not recommend this gun. I do not have any experience with the valken proton but i am sure that the g4 is a poor choice. Hope I could help.
NO! Nipple! The journey's over! We can't go on! -Cr1tikal
http://www.techpb.co...howtopic=214616
