TechPB Forum: rotor vs. pinokio - TechPB Forum
rotor vs. pinokio
#1 User is offline   epic woodsballer
Posted 08 December 2012 - 05:45 PM
I play a lot of woodsball and I need a new loader. What do you think I should get?
OYP Marauders
#2 User is offline   Lyxtwing
Posted 08 December 2012 - 07:13 PM
Both with do you great. I love my rotor, but would actually recommend the pinokio. If I run my rotor dry by mistake, it keeps spinning and can not only give away my location but makes it a bit obvious that I ran out of paint.
You're not your job. You're not how much money you have in the bank. You're not the car you drive. You're not the contents of your wallet. You're not your fucking khakis. You're the all-singing, all-dancing crap of the world.
#3 User is offline   lukylovespaintballin
Posted 08 December 2012 - 11:53 PM
Rotor is very reliable but with the price of 150 and the occasional dump all your paint to fix a jam.The rotor is also very fast when needed(no clue when??) the rotor is very light and has a very low profile compared to the pinokio. The pinokio is very big because of its paintball capacity. The pinokio uses two nine volts while the rotor three double AA's. The pinokio is impossible to jam.(well at least for me) It is very cheap. But the only problem is it has a problem like Halos. Once the shell brakes(which it is prone to) you have to get a new shell. i noticed that the battery efficiency with the rotor was a few cases less than the pinokio. The lid on the rotor is easy while the opposite for a pinokio. Those are my two experiences and IMO get a proph Z2
This post has been edited by lukylovespaintballin: 08 December 2012 - 11:54 PM
My link for my guns
MY FEEDBACK 5/0/0
canscom, on 13 December 2012 - 11:17 PM, said:
#4 User is offline   ccseancc143
  • i'm cool with that
Posted 09 December 2012 - 12:35 AM
The pinokio seems so big.
#5 User is offline   Sydarm
  • XTC + Ninja + Pinokio
Posted 09 December 2012 - 03:51 PM
I play mostly woodsball and love the pinokio. It is very reliable and simple. The size has never been an issue for me, and I like the fact that it holds about 2 full pods.
#6 User is offline   darthp
Posted 10 December 2012 - 11:03 AM
For woodsball I'd say the pinokio. The big profile won't matter too much in the woods with all the small branches and brush for cover. The paint will probably break before it gets to you in a lot of cases.
FEEDBACK +10
#7 User is offline   epic woodsballer
Posted 10 December 2012 - 03:36 PM
I'm picking the rotor because realistically on a average day of play I want something small and fast. It just seems that for the average day I wouldn't need that much paint. But if I went to a lot more scenario games than I currently do then I see why I would go with the pinokio. It was tough choice but the decision had to be made and that's that.
OYP Marauders
#8 User is offline   tyronejk
Posted 11 December 2012 - 06:23 PM
I would also recommend the Rotor. I had both (2 Pinokios actually) and sold my Pinokios and kept my Rotor. They can both feed way faster than necessary but I prefer the Rotor because it's so much easier to take apart and clean. But the Pinokio is much quieter. If the Pinokio's shell was as nice as a Rotor, I'd get a Pinokio. But until then, Rotor for me.
