TechPB Forum: Pumpmag Build - TechPB Forum
Pumpmag Build I am determined to finish a build!
#1 User is offline   WiscoBaller
Posted 17 December 2012 - 06:59 PM
Hey TechPB.
Putting this up a little late, because after my last two builds I put up here I did not finish, I did not want to get the sell bug before I finished this. I do not have all parts in my posession right now, as some are still filtering in and some are being worked on.
I am building a pumpmag.
For those unaware, a pumpmag operates simmilar to an automag, except there is an additional spring between the bolt and the valve, causing it to not reset fully. The pump rod then presses the bolt over the sear, allowing it to fully reset.
Here are my parts so far.
ULE Body Milled (With Luke)
Minimag Valve
AM/MM rail/sear/axle
Benchmark single trigger frame
Shocktech On/Off ASA and rail.
AM/MM Vertical ASA
Bob Long Clamping feedneck
Dye Xcel barrel
XM15 Pump Kit
What I have in my possession right now:
Have:
Minimag valve
Rail/Sear/Axle
Frame
ASA
Vert ASA
Barrel
In mail:
XM15 Pump Kit
Feedneck
Need:
four macro fittings
1'6" macro
To do:
Send rail to Luke to mill.
This post has been edited by WiscoBaller: 17 December 2012 - 07:01 PM
The Hooligans Paintball Team
Bob Long Ripper FST
#2 User is offline   tallsmallboy44
  • Space Cowboy
Posted 17 December 2012 - 08:14 PM
Looks good. Hope you actually finish this one. ;)
Feedback 2/0/0
#3 User is offline   WiscoBaller
Posted 19 December 2012 - 01:16 PM
got the feedneck, rail is shipped out, and pump kit is on the way.
Bob Long Ripper FST
#4 User is offline   tallsmallboy44
  • Space Cowboy
Posted 02 January 2013 - 08:10 PM
Any progress on this?
Feedback 2/0/0
#5 User is offline   WiscoBaller
Posted 02 January 2013 - 09:00 PM
got the pumpkit, the rail and body are still with luke, the feedneck is still here.
Bob Long Ripper FST
#6 User is offline   get.lit.up!
Posted 02 January 2013 - 09:15 PM
Price of build?
#7 User is offline   WiscoBaller
Posted 02 January 2013 - 10:54 PM
Have:
Body-$80
Minimag valve-$30
Rail/Sear/Axle-$20
Frame-$30
ASA-$12
Vert ASA-Free with rail
Barrel-$8
In mail:
XM15 Pump Kit-$60
Feedneck-$8
Need:
four macro fittings-$12
1'6" macro-$1.50
Milling-$60
Total-$320
A bit expensive, but Luke does good work (Rainman would do milling for $40) and I didn't want to use a CF frame, like the metal benchmark better. Pumpmags can be picked up like how I built for around the $300 mark, but this is one I plan on holding onto.
Bob Long Ripper FST
#8 User is offline   WiscoBaller
Posted 03 January 2013 - 11:56 PM
rail and body shipped back yesterday, should be here by the weekend.
Bob Long Ripper FST
#9 User is offline   WiscoBaller
Posted 05 January 2013 - 11:21 PM
It is done, but I am hitting a few snags. I do not have a HP tank currently, so I am looking to buy a HP reg to throw on a tank, and the pump arm is binding on the body. Gonna have to do a bit of tinkering on it, but so far I like it.
Bob Long Ripper FST
#10 User is offline   tallsmallboy44
  • Space Cowboy
Posted 06 January 2013 - 11:25 AM
Looks nice.
Feedback 2/0/0
