TechPB Forum: How to smooth out the Phantom's pump stroke? - TechPB Forum
#1 User is offline   GeezusPB
  • Stud Muffin
Posted 25 December 2012 - 09:53 PM
I have a used phantom set up for open class and the pump stroke is fine, but is there any other ways to make it better? I plan on keeping my phantom for a long time and figured if theres anything I can do to make it better, I may as well do it. So any suggestions? Thanks in advance!
#2 User is offline   get.lit.up!
Posted 25 December 2012 - 10:59 PM
http://www.mcarterbr...ump-stroke.html
I haven't tried any of these btw
#3 User is offline   GeezusPB
  • Stud Muffin
Posted 26 December 2012 - 12:32 AM
Thanks, those are a lot of great tips!
#4 User is online   Antonious
  • Steampunk Afficionado
Posted 29 December 2012 - 03:13 AM
I got Stanchy on MCB to polish my internals and tri-flute my hammer. Its pump stroke seems a lot better now.
Keeping it clean and breaking the springs in helps out too.
This post has been edited by Antonious: 29 December 2012 - 07:06 AM
#5 User is offline   get.lit.up!
Posted 29 December 2012 - 10:31 AM
If you triflute your hammer you will need a lighter valve spring in order use it with higher pressure and co2
#6 User is offline   The-Phantom
  • Rock N' Cock
Posted 06 January 2013 - 06:12 PM
even with stock springs, keeping the gun clean, and breaking the springs in is all you really need to do for a great pump stroke, it's snappy when broken in, but not too heavy
people's phantom's i've shot get binding in the spring, and are "sludged down" when they have not cleaned there gun, and when I take it apart I find the gun filty, after a good scrub down and oil, the gun pumps fine... people just don't take care of their stuff
Please feel free to private message Me if you have a question about something i posted
Pump/Stock Players Clan
-Brett
#7 User is offline   madsnipes
  • Zef Member
Posted 12 January 2013 - 11:25 AM
Phuzzard mod ftw
#8 User is offline   SuperG91
  • You met me at a very strange time in my life.
Posted 13 January 2013 - 05:57 AM
Lube it, stroke it, clean it, lube it, stroke it, clean it.
Simple.
[font="arial, verdana, tahoma, sans-serif"][font="arial, verdana, tahoma, sans-serif"][size="2"]
-ORaNGe-, on 13 June 2011 - 03:00 PM, said:
[size="4"]Super, that is by far the funniest reply I've ever seen in my life, if it weren't so massive I'd quote it in my sig lol
Feedback!
