TechPB Forum: Design suggestions - TechPB Forum
Design suggestions ahead of my engineering class and actually teaching CAD
#1 User is offline   italian Stallion
Posted 28 December 2012 - 10:28 PM
So I am ahead of my engineering class and have moved past the CAD Unit already (Im in highschool) and at this point my skill level with solid works exceeds that of my teacher(s) so I will have some free time to design and I may do something paintball related. I was thinking a trigger. Any other ideas? I'll try to keep the thread updated with problems and successes on a day to day basis.
As for the screen name, its a long story.
#2 User is online   kingJurzy
  • TechPB's best member 2012
Posted 28 December 2012 - 11:13 PM
How much is it to buy a block of aluminum?
FEEDBACK: 20/0/0
#3 User is offline   madsnipes
  • Zef Member
Posted 29 December 2012 - 12:33 AM
http://lmgtfy.com/?q...f+aluminum+cost
OP a trigger would be cool but i doubt it would be all that good unless you know exactly what your doing.
This post has been edited by madsnipes: 29 December 2012 - 12:36 AM
#4 User is offline   tyronejk
Posted 29 December 2012 - 01:27 AM
A bolt!
#5 User is online   kingJurzy
Posted 29 December 2012 - 01:36 AM
Didn't really help me and I am sure I showed you this website.
It would be cool to do a cocker body.
FEEDBACK: 20/0/0
#6 User is offline   italian Stallion
Posted 29 December 2012 - 11:42 AM
http://lmgtfy.com/?q...f+aluminum+costOP a trigger would be cool but i doubt it would be all that good unless you know exactly what your doing.
Well would you care to enlighten me, I would probably be doing it on a 3d printer first, then casting it, we are a fairly new school and the engineering firm that backs us is yet to give us a mill for metal, and I am yet to learn to write CNC programs (freshman in highschool), but a friend and I built a foundry. It wouldn't be nearly as precise as if it were milled but fun and satisfying to do.
View Posttyronejk, on 29 December 2012 - 01:27 AM, said:
A bolt!
Thats sounds pretty cool, and I could accomplish that with the facilities provided.
Didn't really help me and I am sure I showed you this website.It would be cool to do a cocker body.
Cocker body might be a little much, and although pretty, and mechanical, I dont really know enough about them to do one.
#7 User is online   kingJurzy
Posted 29 December 2012 - 11:58 AM
I actually might have something for you.
Taking the plastic sear in the JT Splatmaster and turning that into aluminum. That way I can get mine to shoot over 200 fps.Posted Image
FEEDBACK: 20/0/0
#8 User is offline   italian Stallion
Posted 29 December 2012 - 03:10 PM
actually if you send me pictures and dimensions, I would definitely try to do that.
#9 User is offline   Orange Chicken
Posted 14 January 2013 - 01:00 AM
Ion body kits I could possibly buy from you? A metal replacement body for the brass eagle raptor pump
Panda Man, on 14 April 2013 - 12:26 AM, said:
#10 User is offline   TK-421
  • Me So Horny! :D
Posted 14 January 2013 - 03:27 AM
Do a sick body for an Automag. I've got one you, so you could send the body to me for photos and such. ;)
#11 User is online   Steephill
  • Dota 2 > Life itself
Posted 14 January 2013 - 11:00 AM
A body would be really cool for sure.
This post has been edited by Steephill: 14 January 2013 - 11:01 AM
My Feedback +13/-0
`kook, on 01 February 2012 - 06:06 PM, said:
The gold standard isn't what is most popular.By that logic, Justin Beiber is the gold standard of music.
#12 User is offline   Soldier of Fortune
Posted 16 January 2013 - 03:55 PM
This
View PostPraetorian, on 09 May 2013 - 09:36 PM, said:
View PostGarribean, on 09 May 2013 - 09:29 PM, said:
#13 User is offline   PREDATOR 47
Posted 16 January 2013 - 04:51 PM
If you make a metal sear and trigger for the Splatmaster, you had better make more then one and put them up in the BST.
Join me, put this in your sig and don't feed the fish.
#14 User is online   kingJurzy
Posted 16 January 2013 - 11:17 PM
I have still yet to buy a Splatmaster.
Give me a week and I will pm this guy.
FEEDBACK: 20/0/0
#15 User is online   kingJurzy
Posted 25 January 2013 - 11:52 PM
Hey it has been about a week Posted Image.
I now have a splatmaster and if Italian is still down I can send him pictures of the parts and keep all of you updated.
FEEDBACK: 20/0/0
#16 User is offline   Panda's Revenge
Posted 26 January 2013 - 12:32 AM
Try a Tippmann 98 E-bolt, with a QEV slot, as well as ample space to screw said QEV in.
Yes, I understand that I have schematics but I have to do quite a bit of modifying to make it fit, so I want to see if OP can make a perfect one.
Give me gunz for my gunz.
#17 User is offline   Soldier of Fortune
Posted 29 January 2013 - 01:01 AM
Any plans for other mods than the trigger/ sear assembly?
#18 User is online   kingJurzy
Posted 29 January 2013 - 01:05 AM
Tell me what i should ask him to do.
FEEDBACK: 20/0/0
#19 User is offline   Soldier of Fortune
Posted 29 January 2013 - 01:33 AM
I was just wondering if you were going to upgrade the spring or pad the plunger or something else along those lines. Not so much if you were having anything else made.
I have a few ideas up my sleeve for this platform that I'd like to try out and do some diy guides on, but alas school is going to be eating up the lions share of my time until spring Posted Image
#20 User is online   kingJurzy
Posted 29 January 2013 - 01:38 AM
View PostSoldier of Fortune, on 29 January 2013 - 01:33 AM, said:
pad the plunger
What is the best way to do this.
FEEDBACK: 20/0/0
