TechPB Forum: What I plan on buying in order. - TechPB Forum
What I plan on buying in order. Budget Setup
#1 User is offline   Imtwo
Posted 30 December 2012 - 02:14 PM
1.E-Flex *Won on markerbids*
2.pinokio 90$
3. Ansgear refurb tank http://www.ansgear.c...it6845black.htm
4.2011 PMR proto rail 249$
I Don Not want to but Anything used, I have sever OCD. Witch makes it hard for me to fathom used ANYTHING. The idea of the refurb tank makes me want to pull out my hair. but i could use the money.
What changes would you make? budget is about 600$-650$
This post has been edited by Imtwo: 30 December 2012 - 02:17 PM
#2 User is offline   Garribean
Posted 30 December 2012 - 03:09 PM
I don't think it's Refurbished, but an ANSGear BRAND Tank?
Instead of a Rail, maybe an Etha, Mini, or Proton? That keeps it at Sub $600
This post has been edited by Garribean: 30 December 2012 - 03:10 PM
HD-PVR For Sale/Trade!
HD-PVR
Stuff Below!
Stock, Remoteline,& Paint!
#3 User is offline   crPaliza
Posted 30 December 2012 - 03:39 PM
Yeah,
I doubt the tank is refurbished but just ansgear branded and there's nothing wrong with that.
The Rail's a nice buy. I'm personally not a fan of the Pinokio having seen my friend's. It's bulky and noisy but for a back player it could fare well I guess. I personally would prefer to pick up a Z2, Rotor, or Spire.
#4 User is offline   pb28188
Posted 30 December 2012 - 06:33 PM
Definitly get an etha
#5 User is offline   paintballguy2255
Posted 31 December 2012 - 12:38 AM
I always suggest the pinokio,but if you want to save a couple bucks,the invert too is a good loader for about $75 and comes in matte black,perfect for anyone with OCD(like you or me).Also,the tanks are not refurbished,but merely an ANSgear brand tank.I recommend the Ninja 50/45 or 68/45 because 1.It isn't an "off brand"tank,and 2.ninja regulators are some of the most reliable regulators in the industry,and can be serviced(replace a burst disk,lube the piston,etc)by the user(you).It is a little more expensive,but definitely worth it in the long run.Also,I think that the pmr is a very good gun for the price.I even use one myself,but after $75 for an invert too and $175 for a ninja tank,that leaves you with about $400 to spend on a gun.At that price point,I recommend a used supergun,like an older DM or Ego,but since you want to go the new route,I say either the Drone dx(don't have any experience with it,but alot of people seem to use it and like it),the Proto Reflex rail,or the Etha(all recommended in that order)Hope this helps!
TL;DR:
But these 3 things:
http://www.ansgear.c...ooloaderblk.htm
http://www.ansgear.c...pro-50black.htm
http://www.ansgear.c...ronedxblack.htm
For a total cost of $730
This post has been edited by paintballguy2255: 31 December 2012 - 12:39 AM
#6 User is offline   tot810
Posted 31 December 2012 - 12:54 AM
with a $600 budget and wanting to buy new i would get
1.dye rotor $150
2.ninja 68/4500 $160
3.gog extcy $250
this adds up to $560 and you will have a really nice setup
This post has been edited by tot810: 31 December 2012 - 12:55 AM
#7 User is offline   tot810
Posted 31 December 2012 - 12:59 AM
you could also get a spire instead of the rotor which would add up to $595
This post has been edited by tot810: 31 December 2012 - 01:00 AM
#8 User is offline   paintballguy2255
Posted 31 December 2012 - 01:00 AM
1.dye rotor $150
3.gog extcy $250
IMO a rotor is a tad overkill unless he plans on playing any tournaments anytime soon.The invert too is perfectly fine for rec play,and the gog extcy offers a good chunk less performance than,say,a Drone DX or an Etha.And to me,it looks plain horrid,which I don't like,especially if I plan on paying $250 for something.
#9 User is offline   tot810
Posted 31 December 2012 - 01:06 AM
1.dye rotor $150
3.gog extcy $250
why not get good equipment now so you don't have/want to buy it later but i do agree with the etha or drone
#10 User is offline   paintballguy2255
Posted 31 December 2012 - 02:58 PM
Well I've been using my invert too for a couple months along with my pinokio,and I have yet to see a performance changing flaw about it.And also,if the OP can get together a couple more bucks,I say get the pinokio.It weighs barely over a pound,holds more than most hoppers even without the nose cone,and is a lot smaller profile than it appears to be.
