Reflex 13 vs. Etek4 L T what marker is better in every aspect? price, durability,accuracy, etc
#1
Posted 06 January 2013 - 11:15 PM
#2
Posted 06 January 2013 - 11:18 PM
The Etek is going to be loud but efficient and the Reflex will be smooth but an air hog. Buy used and get a Bob Long G6R.
Lime, on 04 May 2013 - 08:45 PM, said:
FEEDBACK: 20/0/0
#3
Posted 06 January 2013 - 11:21 PM
#5
Posted 06 January 2013 - 11:26 PM
#6
Posted 10 January 2013 - 12:00 PM
(may be its lighter im not sure about that)but it will be laud has more kick and something(bolt) moves in front of you.
but if want something smooth and quiet and also can pay time to maintenance your gun go with proto RR 13(i like it more)
finally i hardly recommond used highends but if intrested in one of them i say proto rr13
This post has been edited by crash000: 10 January 2013 - 12:02 PM
#7
Posted 10 January 2013 - 10:49 PM
#8
Posted 12 January 2013 - 01:11 AM
Feedback: http://www.techpb.co...howtopic=117269 29/ 0/0
Bob Long Marq 6, Dye Rotor with Exalt, 68/4500 Ninja
Gloss Black Bob Long G6R: http://www.techpb.co...howtopic=210825
#9
Posted 14 January 2013 - 06:59 PM
PaintSlinger510, on 12 January 2013 - 01:11 AM, said:
I'm sorry but while the hush bolt slightly changes the sound signature of the Etek the performance increases are more like %10, and some people think the Etek's kick even more with the Hush bolt.
#10
Posted 16 January 2013 - 11:08 AM
The hush bolt improves efficiency and changes the sound signature but not how loud it is (I have an Etek 3 with the hush bolt installed). The hush bolt is lighter so it will move faster thus giving you less smooth of a shot. I personally like the hush bolt better than the cure series of bolts tho'. If you are deciding between the Etek 4 or Reflex Rail 13 they are both backed by fantastic companies and its wether you want reliability and ease of maintenance over shot quality (smoothness) and a quiet sound signature. Not to mention the Etek can get more pods through it than a Reflex Rail. However, efficiency shouldn't really be a deciding factor unless that makes you feel good that your marker can get a few more pods even though practically every field provides free air upon admission.
This post has been edited by LegionPB: 16 January 2013 - 11:09 AM
Sponsored by: DXS, Oringmonkey, MAXS, HK Army
-DPL: Deutschland Paintball League-
Luxe Mob! (Reverse Poison Luxe 2.0)
If You Haven't Already Please Like My Teams Facebook Page! http://www.facebook....tballKL?fref=ts
#11
Posted 16 January 2013 - 11:10 AM
Roddy Koberg, on 10 January 2013 - 10:49 PM, said:
Both companies CS are equally the same, I can say this since I have dealt with them both.
#12
Posted 16 January 2013 - 04:02 PM
I bought a Reflex 2012 as my first gun last June. I used it heavily throughout the summer and here is what I experienced.
1. Love the smoothness and shot quality (Use Valken Graffiti and Redemption Paint)
2. Did not have a problem with Air. I went back to fill up often, but not to an obnoxious level - so Air was not an issue for me.
3. Had a problem with my back bolt cover to my bolt. The bolt cover would unscrew about 1/2 turn and the gun would misfire. I sent it back to dye (3 days in Route), Dye reviewed the issue sent it back the next day with a new bolt cover (1 days at shop) and it took 3 days for the marker to get back to me. So I had a total of 7-8 days without my marker. Pretty remarkable actually and the gun has been perfect ever since. Dye Customer Service was terrific. (if I was more confident - I would have asked that they just send me a new cover. They offered, but I asked them to look at it themselves.)
4. Maintenance was a breeze. I never worked on a marker previously, but I found it pretty easy to maintain. Lotta fun.
5. I only had to replace 2 o-rings the entire summer and that took me less than 3 minutes.
6. Had an issue with my on/off switch, so I took the grips off and found a little paint between the connections. Took me 30 seconds to clean. (So when people say they are always tweaking or fixing something, sometimes it is simple routine maintenance.)
6. My buddy loved my gun so much, he bought one for himself.
7. I would buy it again.
Hope this helps...
This post has been edited by GuyGrim: 16 January 2013 - 04:04 PM
#13
Posted 17 January 2013 - 07:19 PM
Marq7 For Sale
01010000 01100001 01101001 01101110 01110100 01100010 01100001 01101100 01101100 Not a programmer? Oh. Never mind.
#14
Posted 19 January 2013 - 08:31 AM
#15
Posted 20 January 2013 - 10:24 AM
jsg_nado, on 17 January 2013 - 07:19 PM, said:
Similar efficiency? What are you smoking!
And to OP The ergo's of the reflex are almost always the better choice over most guns because of the UL frame but the Etek has wonderful Ergos too you will just need to check both out for your opinion on that.
The reflex is obviously going to be smoother, it is a spool and in no way can you make the etek as smooth as the reflex. The Etek has a better efficiency rating compared to the reflex because once again the reflex is a spool, you sacrifice efficiency for shot quality. Overall I would go (And I did) with the reflex but not the 2013, I'd buy a 2012 used, or even a 2011 (I have that). Good luck
