Whats the best way to empty an HPA tank? Got some regs to switch
#1
Posted 08 January 2013 - 01:13 AM
I have plenty of ideas but I figured there is probably a right way. Thanks for viewing.
#3
Posted 08 January 2013 - 01:16 AM
Should have mentioned I don't have access to a paintball marker at the moment...
#5
Posted 08 January 2013 - 01:18 AM
Does no paintball gun mean you have no access to an ASA or anything like that (got one just lying around)? I just stick it in the ASA, take out the macroline, and turn on the ASA to degas any tanks.
Fear is the mind-killer
#7
Posted 08 January 2013 - 01:26 AM
Kaboom - remote line - got one of those. Thanks guys
#8
Posted 08 January 2013 - 01:29 PM
btw, if you do vent out the air, make sure you let it slowly vent out. dont just crank it all the way down and degas the tank in like 3 seconds.
while it will have probably no noticeable effect, degassing your tank that quickly can stress the materials of your tank.
KPS Paintball • VCU Rams • Richmond Rage•••••••If you need help with a Dye gun, PM me!
#9
Posted 08 January 2013 - 01:55 PM
good looking out, will do
