TechPB Forum: Rotor jam issue - TechPB Forum
Rotor jam issue
#1 User is offline   Pbmcdev
Posted 10 January 2013 - 09:00 PM
hey guys, i havent used my rotor on my `gun yet, but whenever i do a drop test it always jams. i am using white box spectrum paint which is cheap. does this affect it?
thanks
Posted 10 January 2013 - 09:01 PM
Yes. Especially if the paint is badly misshapen and dimpled. Drop tests exaggerate the problem though.
This post has been edited by andrewthewookie: 10 January 2013 - 09:02 PM
Fear is the mind-killer
#3 User is offline   A&MBaller
  • Everyone hates my Axe
Did you get it used?
#4 User is offline   Pbmcdev
Posted 10 January 2013 - 09:15 PM
no
#5 User is offline   darthp
Posted 10 January 2013 - 09:29 PM
Definitely the paint then. I found that the unjamming fin didn't really do a whole lot for me when mine jammed.
FEEDBACK +10
#6 User is offline   andrewthewookie
Posted 10 January 2013 - 09:30 PM
The unjam trigger never really does.
#7 User is offline   crPaliza
Posted 10 January 2013 - 09:36 PM
Lowering the tension on your Rotor should solve the problem. Check out the video below.
#8 User is offline   marceldacs
Posted 10 January 2013 - 09:46 PM
completely. It jams a lot more during drop tests because balls are getting fed close to 50 bps. however at 12.5 it never jams. At least for me.
