TechPB Forum: BL g6r vs dp fx vs ego11 vs dm 13 - TechPB Forum
#1 User is offline   PaintballPassion
Posted 13 January 2013 - 04:34 PM
what's the best one? (what gives u the most bang for your buck)
#2 User is offline   DBeck
  • Dem Milkshakes
Posted 13 January 2013 - 04:38 PM
imo ego 11 used they go for about 700 and its a great gun
  • TechPB's best member 2012
Posted 13 January 2013 - 05:04 PM
Why is the FX up there it is not a supergun.
I say G6R because I liked that one the best but I would then say Luxe then an Ego.
FEEDBACK: 20/0/0
#4 User is offline   BurningPlaydoh
Posted 13 January 2013 - 05:16 PM
G6R if you want best performing poppet
Forget about the FX
Egos are great if you dont know how to maintain your marker
If you want a DM buy a 9/10/11 and save tons of money, they are the smoothest and quietest of the bunch but also need the most maintenance
This post has been edited by BurningPlaydoh: 13 January 2013 - 05:16 PM
