Rifled barrels don't work, but what about spinning barrels?
#1
Posted 16 January 2013 - 11:03 PM
#2
Posted 16 January 2013 - 11:08 PM
(I'm just parroting what I have heard/read, I'm not speaking from experience).
This post has been edited by dustyshouri: 16 January 2013 - 11:09 PM
#3
Posted 16 January 2013 - 11:33 PM
I seem to recall someone actually trying this way back in the day, don't remember if I'm just imagining things or what though.
Fear is the mind-killer
#4
Posted 16 January 2013 - 11:52 PM
#6
Posted 17 January 2013 - 12:17 AM
This post has been edited by andrewthewookie: 17 January 2013 - 12:19 AM
#7
Posted 17 January 2013 - 12:40 AM
andrewthewookie, on 17 January 2013 - 12:17 AM, said:
Aye, I was reading about those just now, and saw you had posted
Anyways... I guess if you want hard numbers and explanations about the physics of paintballs and what rifling can and can not do, http://www.forums.xkcd.com/ would be a good place to go(unless there are some guys around here who are into physics). I guess the biggest problem trying to accomplish any of these things(rifling, dimples) is consistency. It seems like a very fickle thing to mess with, and when you're manufacturing hundreds of thousands of paintballs, it's hard to maintain that degree of consistency.
This post has been edited by dustyshouri: 17 January 2013 - 12:42 AM
#8
Posted 17 January 2013 - 10:43 AM
#9
#10
Posted 17 January 2013 - 12:13 PM
Paintballs are capable of spinning just fine. For evidence, look to the apex barrel. Or, you could do this experiment on your own:
Using your fingers, spin a paintball like a top as you drop it (from about 1") onto a smooth surface (i.e. glass table). If you give it enough RPM, it will spin for much longer than even the longest paintball shots.
With rifled barrel designs, it's difficult to impart a consistent spin to a paintball due to the need to grip the shell tightly enough without damaging the shell. Tom Kaye's solution to see if spinning even made a difference was to use a spining barrel. In his tests, he found no benefit. What I don't know is if he tried applying rifling or, spinning the barrel with his Perfect Circle paintballs.
With all that being said, there are two major obstacles for a spun paintball to overcome before there is any benefit to accuracy:
Vortex shedding- Being such a lightweight round projectile, they are vulnerable to vortex shedding which tends to push the projectile from it's intended course.
The First Strike round ignores all of these features: they're self-spinning in flight. The skirts are slightly lopsided but, the diameter of the body (the widest part of the round) is next to perfectly circular. The skirts reduce the drag of the rounds.
The things I suspect but, I'm unsure of:
- The finned skirt may reduce the laminar flow that leads to vortex shedding.
- The hollow skirt might induce a low pressure zone that may increase drag. It's obviously not enough to negate the reduction in drag gained from the skirt.
- The fill can separate in storage (an oily fluid and a thicker paste). This may lead to rounds being out of balance until centrifigal forces remix The fill. If so, would pre-spinning within the confines of the barrel help these rounds stabilize quicker?
- Since the rounds rely on drag to start spinning, would pre-spinning them reduce the drag enough to make a difference in range?
T9.1SD "Totmacher"| Woodstalker Ion MK-II | SP-1 W/Qloader
Reference Threads:
First Strike Field Listing | External Ballistics Primer
#11
Posted 17 January 2013 - 04:00 PM
The barrel would unscrew and fall off.
#12
Posted 17 January 2013 - 04:58 PM
#13
Posted 18 January 2013 - 11:52 AM
I would be curious to see if the skirt could be formed in to a cone shape a the end in an attempt to reduce the low pressure zone behind the round, and if that would give more range.
I know it is very impractical to manufacture a first strike this way but it would be interesting to see none the less
#14
Posted 18 January 2013 - 12:42 PM
Well, there is the SniperBall, that's the primary method they rely upon. Unfortunately, they don't use spin stabilization and, it adds mass to a normal paintball.
I'd be interested in a projectile that had a more conical tail and, spin stabilization but, kept the same paintball weight and a greater fill volume than an FS round. I don't expect to see this round mainly because as you increase the mass of the shell, you must decrease the mass of the payload.
Reference Threads:
