TechPB Forum: Boss Bolt V2 vs. Techt Bolt vs. Lurker Bolt - TechPB Forum
#1 User is offline   00mikey03
Posted 22 January 2013 - 09:16 PM
Hello Everyone, first of will these work on the Mini? And if they do, which one is the best? Thanks
Mikey
#2 User is offline   nighthunter
Posted 22 January 2013 - 09:28 PM
They should work. Of the two, probably the Boss bolt is better, however I'd suggest you also look at a Lurker bolt: Lurkerpaintball.com They're a small company, but they make amazing products.
View PostAntonious, on 23 December 2011 - 04:37 PM, said:
My Gearbag Sale!
  • TechPB's best member 2012
Posted 22 January 2013 - 09:30 PM
The TechT bolt is useless and the Boss V2 and the lurker are the best out there.
The Boss bolt is a lighter "drop in" bolt made from a different material to make it lighter and the Lurker bolt is made from the same light material "delrin" but changes the way the marker fires.
All bolts should work with your marker if they are made specifically for your marker i.e. you cannot fit a G6R TechT bolt in a Mini.
FEEDBACK: 20/0/0
#4 User is offline   00mikey03
Posted 22 January 2013 - 11:07 PM
Out of the Boss V2 and the Shocker, which one is better?
Posted 22 January 2013 - 11:35 PM
Shocker?
FEEDBACK: 20/0/0
#6 User is offline   nighthunter
Posted 23 January 2013 - 12:16 AM
I hope you mean the Lurker bolt.
A shocker is a great thing to have, but I highly doubt you could fit the whole thing inside of a mini.
On a more serious note, make SURE that whatever you're about to buy says it's for the Axe/Mini. The coolest bolt kit in the world won't help much if it doesn't fit your gun.
My Gearbag Sale!
#7 User is offline   chadsan
Posted 23 January 2013 - 12:23 AM
Lurker Eigenbolt - good for mini and axe. http://www.lurkerpb....-eigenbolt-kit/ - This is the only bolt that is actually redesigned for increased performance. The boss is an excellent product but it is just a nicer version of the stock bolt. Same with the techT. The Lurker is superior for many reasons that are all covered on their website.
#8 User is offline   madsnipes
  • Zef Member
BLurker > Lurker > Boss w/ spring kit > Boss w/ no spring kit > Stock bolt > TechT bolt
#9 User is offline   Cj R
  • I'm still laughing at this picture.
Posted 23 January 2013 - 12:25 AM
I lol'd hard at that one. :D
Feedback http://www.techpb.co...howtopic=219021 1/0/0
The best customer service is the one you don't have to call in the first place.
#10 User is offline   kingJurzy
Posted 23 January 2013 - 12:26 AM
That
FEEDBACK: 20/0/0
#11 User is offline   The Dad
Posted 24 January 2013 - 11:57 PM
Tried them all in my axe. Tech T (ok, but not worth the money with other better cheaper options available).
Boss bolt xsv more consistent however tended to stick to much, thereby decreasing smoothness. Lurker, interesting install, however smoothest of all bolts thereby leading to more consistent ball flight. Dwell settings on my axe are higher then Lurker recommends or it doesn't shoot very well. Combined this with a Lurker barrel and I have had a lot of comments from tournament players on how quite this set is. One ref did not even hear me shoot someones shoe from 10 feet away. I had to call a paintcheck on the guy. Overall, smoothness is what you are trying to achieve, been down this road....choose Lurker 1st, boss 2nd. Or try both as there is a blurker set up out there I have not tried.
#12 User is offline   The Dad
Posted 25 January 2013 - 12:00 AM
Does anyone know what the blurker set up consist of and can you give detailed instructions on how to install?
#13 User is offline   unfated33
  • Punk Engineer
Posted 18 February 2013 - 08:16 PM
Late to the party, but you can find info about the blurker modification here: http://www.pbnation....d.php?t=3821379
Basically, you take the Boss bolt spacer and add it to a Lurker bolt. You'll also see in that post that after getting feedback from the users that Lurker started adding a flat o-ring to his package to accomplish the same result. I do not know of anyone that's tried both the Boss spacer and the Lurker flat o-ring to see if it works as well. Users seemed to be very happy with the blurker performance.
