TechPB Forum: Wich Would Be the best Sight? - TechPB Forum
#1 User is offline   Blazingsebas
Posted 26 January 2013 - 07:59 AM
Best Sights For Mil-sim markers?
I Went thinking about the Sightmark Ultra Shot Pro Spec Sight NV QD,But since i saw than the Rail where like too "Big" For the marker Rails i was scared to bought-it and at the time i have it in my hands the sight didn`t went to fit in the marker also i will like to know if im going to have more accuarcy with the sight,I would also like to know if there is the chance of having night vision incorporated but isnt the real fact just since i saw than the Sightmark had it i would like to have the same featura but as i told it isn`t the real fact.
Attached File  41EFM4CyY9L._SL500_AA300_.jpg (9.67K)
If you see actualy this one has like a middle rail
Attached File  416eg2-YmYL._SL500_AA300_.jpg (10.91K)
I would actually something than i can aim on it
Thank you for reading the post and hope to know about your personal experience with paintball sights
#2 User is offline   Blazingsebas
Posted 26 January 2013 - 08:00 AM
Attached File  41BadSZUdmL._SL500_AA300_.jpg (10.09K)
This post has been edited by Blazingsebas: 26 January 2013 - 12:13 PM
#3 User is offline   Blazingsebas
Posted 26 January 2013 - 08:01 AM
#4 User is offline   Blazingsebas
#5 User is offline   Blazingsebas
Posted 26 January 2013 - 08:02 AM
#6 User is offline   G4paintballer
  • Gun/gear whore
Posted 26 January 2013 - 09:39 AM
Sights are pretty much useless.
/thread
Feedback 10/0/0
#7 User is online   TacticlTwinkie
  • *insert witty title*
Posted 26 January 2013 - 11:59 AM
Beyond cosmetic appeal, they don't offer much for paintball. Paintballs are not accurate enough, they don't always fly strait, and they ark a bit. A sight won't help you shoot more accurately.
#8 User is offline   Blazingsebas
Posted 26 January 2013 - 12:13 PM
Thanks
#9 User is offline   PREDATOR 47
Posted 26 January 2013 - 12:16 PM
Did the question need to be posted FIVE times? And no, sights are mostly a waste of money for paintball, unless you use first strikes, then they can be helpful.
Join me, put this in your sig and don't feed the fish.
#10 User is offline   Blazingsebas
Posted 26 January 2013 - 05:47 PM
It is the first time i make a post i didn`t even know how to post-it thats the why it is 5 times.
#11 User is offline   Jawz
  • MOONBASE!
Posted 07 February 2013 - 04:45 PM
well I wouldn't say they are useless it adds a cool look to your marker and give you that pinpoint direction your barrel is pointing giving you at least a general area where your paintballs are going to fly at.
View PostJ4 Paintball, on 24 May 2013 - 01:12 PM, said:
Jawz is our new favorite customer. You can have the first one Sir!
GODDAMNIT OEF!!! STOP CHANGING MY SIG!!!!
#12 User is offline   BraiNfreeZe
Posted 08 February 2013 - 07:23 AM
Sure its got a tacticool look but other than that you wont need one, and you're better off putting money towards a better barrel if you want accuracy.
"May God Have Mercy On My Opponent, Because I Sure As Hell Won't."
#13 User is online   TacticlTwinkie
Posted 08 February 2013 - 10:22 AM
Unless the inner surface of your barrel is complete trash, the barrel won't make a measurable difference in accuracy. Your money is better spent on quality paint.
#14 User is offline   BraiNfreeZe
Posted 08 February 2013 - 11:33 AM
under boring gives a tighter feel of the paintball and the barrel. THe tighter the barrel is, while still being able to allow the paintball to go through will give you the best accuracy.
This post has been edited by BraiNfreeZe: 08 February 2013 - 11:33 AM
#15 User is offline   GeezusPB
  • Stud Muffin
Posted 08 February 2013 - 11:36 AM
It seems like it would, but punkworks did a TON of tests proving that to be wrong. Accuracy is dependent on paint and how clean your marker is.
#16 User is offline   LUXOR54
  • TechPB's smart ass
Posted 08 February 2013 - 11:38 AM
sorry, but that information is false. you will get the same accuracy out of a .695 as you will out of a .678, you may not get the same consistency, but you'll get the same accuracy
New found pumper,
Set-up: Black/gold E2 Karnivor, Dye rotor, Guerrilla air 68/4500, CP 14" .685, Black/Gold Dye I4's, Dye core pads, Venomwear, Etek3 LT. Orange 2k5 superstock, CCM'd
Proud Canadian citizen
#17 User is online   TacticlTwinkie
Posted 08 February 2013 - 12:53 PM
It's been tested and documented. Barrels don't make a measurable influence on accuracy. Paintballs are too poor of projectiles to see any sort of difference between underboring or overboring or matching, and between different brands of the same bore size.
#18 User is offline   BraiNfreeZe
Posted 08 February 2013 - 06:28 PM
.......Not saying that I don't trust punkworks and all but I trust Mike more....and in my experiences it works much better....
