TechPB Forum: Gravity fed vs Electric loader - TechPB Forum
#1 User is offline   Alexjo
Posted 27 January 2013 - 11:10 AM
Should I spend the extra 30 bucks to get an electric loader like the dye rotor or the halo? Does it make a big difference? I've played with a gravity fed hopper, it didn't chop any paint and the only problem is sometimes two balls are shot at once.
#2 User is offline   BurningPlaydoh
Posted 27 January 2013 - 11:43 AM
The two balls firing is due to bad detents on the marker you were using. It really depends on how fast you're going to shoot whether you need a force fed loader or not.
  • TechPB's best member 2012
Posted 27 January 2013 - 11:52 AM
Lime, on 04 May 2013 - 08:45 PM, said:
FEEDBACK: 20/0/0
#4 User is offline   Rhino1909
Posted 27 January 2013 - 01:05 PM
Get an empire halo too
#5 User is offline   bassfisher
Posted 27 January 2013 - 06:11 PM
If it is a pump, don't worry about it, I use a primo on mine. If it is an electro, than most Definately its worth it.
Carolina Riot Scenario Team
#6 User is offline   walk on pro
Posted 27 January 2013 - 06:14 PM
um... the 30 extra bucks...... *cringe* you do realize new and used a rotor will not go for 30 bucks and mayyyybbee with the halo.....
#7 User is offline   Alexjo
Posted 27 January 2013 - 06:33 PM
I meant 30 dollars more than a decent gravity fed loader, like the proto primo. But I see what mean, I didn't realize the Dye rotor was 150 bucks .
#8 User is offline   kingJurzy
Posted 27 January 2013 - 06:35 PM
$90 used
FEEDBACK: 20/0/0
#9 User is offline   marceldacs
Posted 28 January 2013 - 12:59 AM
Electric loaders are nice to have but you will be shooting much more paint. For you it sounds like a used halo too will work well. I have one and they work but I like my rotor better. My halo is really rough on paint for some reason.
#10 User is offline   Steephill
  • Dota 2 > Life itself
Posted 28 January 2013 - 08:28 AM
Totally worth it, gravity feeds are only good for pumps. It's worth it to have a electronic hopper even if you have a spyder or tippmann.
My Feedback +13/-0
`kook, on 01 February 2012 - 06:06 PM, said:
The gold standard isn't what is most popular.By that logic, Justin Beiber is the gold standard of music.
