TechPB Forum: Virtue spire vs. Prophecy z2 - TechPB Forum
#1 User is offline   Etek3am ftw
Posted 28 January 2013 - 09:21 AM
i wanna get one of the 2 (i dont like rotors) which one of the 2 feeds faster, has better battery life, easier disassembly, never jams, greater capacity, looks and operation. i need a fast answer i might get one in 2 days.
and which one would look better on my etek 3
thanks
#2 User is offline   BraiNfreeZe
Posted 28 January 2013 - 09:28 AM
The spire looks amazing so far and it comes in Orange. However it still pretty new
#3 User is online   Carolus Rex
  • I won at life once.
Posted 28 January 2013 - 09:51 AM
Only thing i can comment on is the dissassembly where the spire clearly
wins. There is plenty of videos on youtube were they dissassemble the spire.
#4 User is offline   BurningPlaydoh
Posted 28 January 2013 - 09:55 AM
The Spire is gentler on brittle paint and has greater capacity.
#5 User is online   Rotozip2
Posted 28 January 2013 - 10:52 AM
I like my Z2. And yes that is all of the opinion I can offer on it. Posted Image
#6 User is offline   marceldacs
Posted 28 January 2013 - 11:34 AM
between those two, spire. Mainly because it has easier disassembly. However, i like the rotor better than both.
#7 User is offline   Etek3am ftw
Posted 28 January 2013 - 12:43 PM
but which one wil feed the fastest and at a constant rate. i heard the spire skips a little
#8 User is offline   marceldacs
Posted 28 January 2013 - 12:45 PM
The spire has some issues when feeding the last few balls. My teammate has this issue and wants a rotor now. The rotor is fast and consistent because it runs continuously even when you are almost out of paint.
#9 User is offline   Etek3am ftw
Posted 28 January 2013 - 03:51 PM
will both loaders keep up with 25bps. thats all i need to know
#10 User is offline   Pbmcdev
Posted 28 January 2013 - 03:56 PM
Rotor
#11 User is offline   Etek3am ftw
Posted 28 January 2013 - 04:50 PM
View PostPbmcdev, on 28 January 2013 - 03:56 PM, said:
Rotor
to be honest i dont like the rotor because of its shape and capacity
#12 User is offline   marceldacs
Posted 28 January 2013 - 05:13 PM
Rotor still has a nice capacity at around 180. It is also very consistent because the arm is always doing work
#13 User is offline   BurningPlaydoh
Posted 28 January 2013 - 07:50 PM
I dont know why or how you would be shooting that fast, but yes, they will both keep up with 25 bps.
#14 User is offline   crPaliza
Posted 28 January 2013 - 10:12 PM
I've only used the Spire once on the field so I have yet to test it more. At first glance, it definitely feels better than the Z2. I can definitely tell you that when I did droptests with the Spire it did better than the Z2.
View PostEtek3am ftw, on 28 January 2013 - 09:21 AM, said:
which one:
feeds faster Does it matter? They will both feed perfectly fine within legal limits. (Again, only used the Spire once on the field but I doubt it has feeding issues based on the drop tests I've made and the overall way it works.)
has better battery life Spire (based on claims so don't hold me to it. Also keep in mind that the Spire uses only 3 AA's as opposed to the Z2's 4 AA's.)
easier disassembly Spire for sure (It's really not necessary to fully dismantle a Z2. However, a full disassembly on a Z2 is definitely annoying mainly because of the freaking e-clips. >.<)
never jams Supposedly Spire (The Z2 rarely jams though and you have the rip drive in case all else fails... Lol, no battery!)
greater capacity Spire for sure (Z2's ball count is more close to like 180-190ish versus the Spire's true 200 ball count.)
looks opinion
thanks
This post has been edited by crPaliza: 28 January 2013 - 10:20 PM
#15 User is offline   DBeck
  • Dem Milkshakes
Posted 28 January 2013 - 10:19 PM
my rotor with a speedfeed fit 196 balls so i dont see why the capacity is a factor when the z2 gets about 150
#16 User is online   Jaccen
Posted 29 January 2013 - 06:58 AM
The regular cone Z2 gets anywhere from 175 to 185 in my experience. The nose cones allow some flexibility in that regard, also.
#17 User is offline   PrimeTimePred
Posted 29 January 2013 - 08:48 AM
Get the Spire, get it and never look back
#18 User is offline   pbbandit
Posted 29 January 2013 - 02:43 PM
I was in the same position a few weeks ago. I went with the Spire. Not only is it quiet, sleek, and fast, but it's durable as hell! This thing can take a serious hit. It's lighter and stronger than the z2. Trust me it rules. The feed gets a little annoying if your gun has serious kick but with my axe and infamous bolt it is perfect. Both are great and you will be happy with either, but in the end I think the Spire is better IMO.
#19 User is offline   Etek3am ftw
Posted 02 February 2013 - 07:52 AM
i got the spire and love it. it shoots 25bps just like i want it to
#20 User is offline   illmatic
Posted 02 February 2013 - 10:35 AM
why on earth are you shooting 25bps?
For Sale :
http://www.techpb.co...howtopic=179896 TechPB Jersey / Dye Jersey
http://www.techpb.co...howtopic=179889 Bob Long Vice
http://www.techpb.co...0 Dye UL Back / Stiffi CF Front
