TechPB Forum: Replace Trigger Proto Rail ? - TechPB Forum
#1 User is offline   whiteraven81
Posted 30 January 2013 - 09:53 AM
Hi,
im trying to replace the trigger on my proto rail 2011
But i Can not get the tigger pin out.
i've tried with a hammer and allen key hitting it out but it wont budge more then half a inch not matter how hard i hit.
am i doing something wrong ?
#2 User is offline   stinkfingr
  • time traveller
  • Location:Trapped Between The Worlds Of Make Believe, And Large Giant Multi Colored Shimmering Jello Cubes
Posted 30 January 2013 - 01:58 PM
i hate to ask the obvious, but have you tried hitting it from both pin holes ? ... left side and right side ... maybe it is a tapered pin, so that it only goes in one way and out one way.
could it be that it is actually a threaded hole with a long screw ?
#3 User is offline   OBF
  • Haters gonna hate.
Posted 30 January 2013 - 06:04 PM
I had the same issue. Hit the other side. :P
#4 User is offline   Nokified
Posted 30 January 2013 - 09:43 PM
Hit it from the left face when you hold you're marker. You don't need to use a hammer. Elbow grease and Allen key
