TechPB Forum: Proto Reflex Rail 2013 - TechPB Forum
Proto Reflex Rail 2013 is it a good tournament level marker?
#1 User is offline   ckenney12
Posted 31 January 2013 - 02:59 PM
Is the proto reflex rail 2013 a good tournament level marker? Or can I Find a better marker for around the same price? If so what is it? And no I will not buy used
www.sjnightmare.webs.com **Team Tryouts changed to March 23rd. Check out post in NJ fourm for more info!
#2 User is offline   unfated33
  • Punk Engineer
Posted 31 January 2013 - 03:05 PM
Some of this is just personal opinion, but I find almost all of the markers that are in the same general price range (Crossover, Axe, FX, and Invasion) to be superior to the Reflex Rail, and the Etek3 is evenly comparable for those that want a stacked tube poppet but must have an on/off ASA.
The Reflex looks nice aesthetically, and is very smooth comparatively, but I did not like the ergonomics and especially did not like the trigger. If I was buying a tournament level marker that would be fairly plug-and-play, I don't know that I could pass on the Axe for its price, especially a good used price.
EDIT: I forgot the Drone DX. I've heard it's very very good, I just don't have experience with it. I have used the Cyborg, and I thought the trigger on it was terrible - supposedly the terrible trigger is a "feature" of Macdev.
This post has been edited by unfated33: 31 January 2013 - 03:08 PM
#3 User is online   tallsmallboy44
  • Space Cowboy
Posted 31 January 2013 - 04:01 PM
The Reflex '12 is the same marker, just milled different, so if you want a Reflex, get the '12 and save yourself some money.
Feedback 2/0/0
#4 User is offline   PandasEverywhere
Posted 31 January 2013 - 04:24 PM
For tourny play I would get an Axe, it is going to be the gentlest on paint and tourny paint is fairly brittle usually.
#5 User is offline   TooTallNiCo
Posted 31 January 2013 - 04:44 PM
I mean yeah you could get one and jump in and play a tourney with it and it'll perform just fine for you. But there are some other options out there that you might be happier with. Personally, I would get a used 2011 G6R
#6 User is offline   Skippie
Posted 31 January 2013 - 05:07 PM
The Reclex rail is a good gun, But i guess its just personal opinion on what you want for a 500$ gun Bro :)
Reflex*
Current Setup: Planet Eclipse Geo 3 (Black/Teal), 68 4500 Ninja tank (grey Ghost), and a Dye Rotor (Liquid Grey)
#7 User is offline   walk on pro
Posted 31 January 2013 - 05:23 PM
get the 2012, its the same gun but different annos trust me. the 2011 proto (not reflex) has the same bolt as all the reflexes and they cost twice as much
#8 User is offline   ckenney12
Posted 31 January 2013 - 10:56 PM
thanks guys
#9 User is offline   Jawz
  • MOONBASE!
Posted 31 January 2013 - 11:43 PM
PM8
View PostJ4 Paintball, on 24 May 2013 - 01:12 PM, said:
Jawz is our new favorite customer. You can have have the first one Sir!
GODDAMNIT OEF!!! STOP CHANGING MY SIG!!!!
