TechPB Forum: 12 Gram Changer vs. 13/3000 - TechPB Forum
#1 User is offline   GeezusPB
  • Stud Muffin
Posted 02 February 2013 - 02:00 PM
Ive been running a CP gas-thru and an asa on my open class phantom with a 50 rd and 50/4500. I dont want to run back bottle anymore and was thinking of either running a 12 gram changer or a 13/3000 in the chamber(?) threads (where the reg/gas-thru goes). I know some of you guys will say that it's all personal opinion, but I want to know what your opinions are. How long is a 13/3000? How heavy is it? Is it really uncomfortable to use compared to a 12 gram changer? Thanks for any replies! I also only use 50 rounds in a game, I dont take any extra paint.
Edit: this probably should have gone in the vs forum... Sorry
This post has been edited by GeezusPB: 02 February 2013 - 02:13 PM
#2 User is offline   get.lit.up!
Posted 02 February 2013 - 02:42 PM
Well I managed to squeeze out 100+ ball out of my phantom and personally I would keep it the way it is and swap tanks, more comfortable imo.
12g wise I've been able to get 20-30 usable shots per 12g so if you like to be light and plan on only 50 balls a game this is the way to go and get like a wristband to hold 1-2 extra 12g
For me 13cui bottomlined as in your pic, pocket hopper, 50rd pod and i'd ready to mow people in the face
#3 User is offline   GeezusPB
  • Stud Muffin
Posted 02 February 2013 - 03:10 PM
You sir, are one of the most helpful people on this forum. You have pretty much walked me through getting into pump :) thanks for the advice!
#4 User is offline   Antonious
  • Steampunk Afficionado
Posted 02 February 2013 - 03:45 PM
I had a 13/3k once and hated it. It was too short and too skinny for me when on a bottom-line setup on my phantom, but too long and awkward to use in a vertical setup. I instead opted for a 45/45 on a bottom-line and never looked back.
However, on my micro-phantom that I run pistolero-style, a 12-gram dropout changer is perfect.
#5 User is offline   Demon
  • Master Tech
Posted 02 February 2013 - 09:57 PM
for me the convenience of constant air is just too much compared to 12'ies and it's much more expensive for me to use 12 grams. so i roll with a 68/45 or 13/3k
#6 User is offline   get.lit.up!
Posted 03 February 2013 - 01:23 PM
No worries I try. What would be pretty bad ass is rocking a phantom with an AGD 6 pak
#7 User is offline   Antonious
Posted 03 February 2013 - 02:38 PM
Was almost able to do that before a guy sniped my bid at the last second on ebay. I was pissed.
#8 User is offline   get.lit.up!
Posted 03 February 2013 - 04:45 PM
I would be too, don't they have a few on mcb?
#9 User is offline   Demon
  • Master Tech
Posted 04 February 2013 - 12:56 AM
got $300+ ? and the last one on MCB was like last year
